Volvo 850 broken hood cable solution
JimBee
Has thanked: 25 times
Been thanked: 42 times
Re: Volvo 850 broken hood cable solution
Post by JimBee »
Two p80 nightmares that I've mentioned on MVS are being stuck somewhere on the road with an open sunroof that you can't close in a period of stormy weather and a broken hood cable if you don't have the auxiliary dongle described here.
How do you get in there? I don't have time to look it up right now, but I posted another one featuring 2 stiff wires (like coat hanger wire) about 10 inches long with a hook at the end. You do need to sacrifice the marker light retention spring to go in through the cable hole, but those springs are cheap online (a couple years ago). You need to cut the spring. If you try to pull it too hard the plastic lug the spring connects to will break—then you need a new light housing (they're still available, I think Rock Auto had them a couple of years ago; might still have).
The right (US passenger) side is easiest, b/c the trip lever is on the outboard side of the latch. If I recall correctly, you can almost see it with a flashlight. The left (US drivers side) is harder to see. You kind of have to have a sense of where you're fishing. I couldn't get to it from the underside (not that I needed to, thankfully), so again you go in through the cable hole behind the marker light. I posted photos of the fish wire I made up and instructions about how to orient it as you poke around in there trying to get a hold of the lever. It's doable. Of course, the best preventive measure is what's in this thread :D
Has thanked: 1502 times
Been thanked: 3817 times
Sunroof backup
Heavy construction gauge black vinyl garbage bag, also used for lying on while changing wheels or a LBD club dress, something Dads never need to see on daughters.
Also useful as tarp to protect car transporting plants or messy stuff, you ca out the grandkids in them while eating ice cream to protect the leather, too. Cut breathing holes
Duct tape to match colour of car.
Just tape it over the hole in bad weather.
