Is this a B2524T motor?
I've got one that's supposedly a '99 motor. (They used them for 97-99) going into my '78 240.
1998 V70 GLT 19T Build
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
- Has thanked: 987 times
- Been thanked: 1075 times
How do you plan to mount a white block in the 240? Rear or front drive? Transmission?Chuck W wrote: 01 Jan 2020, 09:09 Is this a B2524T motor?
- Chuck W
I won't hijack his thread with details, but it's not too terribly difficult to mount a 5-cyl whiteblock in RWD config.volvolugnut wrote: 01 Jan 2020, 09:19How do you plan to mount a white block in the 240? Rear or front drive? Transmission?Chuck W wrote: 01 Jan 2020, 09:09 Is this a B2524T motor?
Ok, thanks. I will search MVS for more info.Chuck W wrote: 01 Jan 2020, 09:36 I won't hijack his thread with details, but it's not too terribly difficult to mount a 5-cyl whiteblock in RWD config.
- Has thanked: 316 times
- Been thanked: 531 times
Yes, B5254T. This is the original '98 motor, if yours is a '99 should be a B5244T with single VVT.Chuck W wrote: 01 Jan 2020, 09:36 I won't hijack his thread with details, but it's not too terribly difficult to mount a 5-cyl whiteblock in RWD config.
That'll be awesome in a 240, my cousin really wants to do that with his. Really not too hard, just use an adapter plate and a Ford T5 or CD009 trans and a 960 subframe. Then get a shortened white block 6 cylinder sump. Then a complete harness for M4.4 or run Megasquirt.
The tap arrived yesterday for the barbs for the NA intake manifold. Really easy to modify it for the turbo... all you need to do is add two barbs. You may only need to add one depending on the year, but for this '98 it requires three total (excluding the brake booster)... one for the purge valve, one for the CBV, and one for the fuel line. The NA '98 manifold only has one.
Simple process... I used an automatic center punch to start, then used a 13/64" drill bit for pilot holes. Then moved up to an 11/32". Technically for an M10x1.0 tap, you're supposed to use a 9.1mm bit. 8.9mm or 11/32" are acceptable for M10x1.25", and the 11/32" worked perfectly for the 1.0 being that it was just 0.2mm smaller.
Be sure to use cutting oil, and clean the intake manifold thoroughly before installing! This will all go back together after I replace the leaking thermostat housing gasket, which of course is not available locally. That's on the way from eEuro now.
Fresh threads ready for the barbs! Just like the turbo intake manifold! The other option is to port/gasket match the throttle body on the turbo intake manifold (like I mentioned before), but this is easier. I don't have any good carbide bits for my die grinders, so it was going to take WAY too long to get through it.
- Chuck W
bmdubya1198 wrote: 01 Jan 2020, 11:14
It's got the updated oil cooler, COP, and ExVVT.
B5244T is a later P80 motor (00-02)
I think we were short a barb on the swap in the wife's GLT, and I wound up just adding a "T" to the vacuum line. Had I realized it beforehand, I probably would've done the same as you and drilled/tapped.
- Has thanked: 311 times
- Been thanked: 817 times
Just catching up, reading about your RTV finding. When I bought my 98 GLT as a rescue project, the cam cover was RTV'ed and puking oil all over the place. I cleaned it up good and 60,000 miles later all seems to be well.
- RickHaleParker
- Been thanked: 977 times
B5254T was used 1997-1999. B5244T was introduced in 2000.bmdubya1198 wrote: 01 Jan 2020, 11:14 Yes, B5254T. This is the original '98 motor, if yours is a '99 should be a B5244T with single VVT.
B5254T Applications:
- 1997 Volvo 850 badged as 850 AWD or 850 2.5T
1997–1999 Volvo S70 badged as S70 2.5T or S70 AWD
1997–1999 Volvo V70 badged as V70 2.5T,[161] V70 AWD or V70 2.5T AWD
1998–1999 Volvo V70 XC badged as V70 XC AWD or V70 XC 2.5T AWD
1998–1999 Volvo C70 badged as C70 2.5T (convertible)[162]
1998–1999 Volvo C70 badged as C70 2.5T (coupé)
B5244T Applications:
- 2000 Volvo S70 badged as S70 2.4T or S70 2.4T AWD
2000 Volvo V70 badged as V70 2.4T or V70 2.4T AWD
2000 Volvo V70 XC badged as V70 XC 2.4T AWD
2000–2002 Volvo C70 badged as C70 2.4T (convertible)
2000–2002 Volvo C70 badged as C70 2.4T (coupé)
Active
Past
Past
That's right, the '99 motors were still incorrectly designated as 2.5s... I don't know why Volvo did that. Weird that they never updated the designation for the RN version, like how the B5234T was replaced by the B5234T3.
No more updated after adding the barbs, just waiting on parts now! I went ahead and changed the oil trap in my 940 and the voltage regulator on my V70R. Hopefully that'll take care of the dimming lights every time there's the slightest electrical load.
It makes for a big mess, that's for sure. Anaerobic sealant is the only way to go!erikv11 wrote: 01 Jan 2020, 12:09 Just catching up, reading about your RTV finding. When I bought my 98 GLT as a rescue project, the cam cover was RTV'ed and puking oil all over the place. I cleaned it up good and 60,000 miles later all seems to be well.
- RickHaleParker
Both engines are the exact same displacement, 2,435 cc.bmdubya1198 wrote: 01 Jan 2020, 18:38 That's right, the '99 motors were still incorrectly designated as 2.5s... I don't know why Volvo did that.
Rounded up for the US market where oversized sells.
Rounded down for the European market to reduce taxes.
Anaerobic means it will not phase change from liquid to solid in the presence of Oxygen and/or the absence of Metal ions. In other words it must be in contact metal and isolated from air before it will cure.
Active
Past
Past
- 1132 Views
Last post by dublgg
- 25 Replies
- 6980 Views
Last post by CIK7
- 527 Views
Last post by Goupil
- 1561 Views
Last post by mikeonabikesmith
- 249 Views
