The strut comes off the car, the spring gets compressed, old parts removed, new parts on.
Plan a half day for both sides,
FDPP #2
- Has thanked: 1611 times
- Been thanked: 4072 times
- Has thanked: 316 times
- Been thanked: 531 times
Yes, that’s the correct way to do this. You need to remove the strut assembly from the car to disassemble it.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
I'm only fixing the right side, since that's the side with the bad strut.abscate wrote: 31 Jul 2020, 20:30 The strut comes off the car, the spring gets compressed, old parts removed, new parts on.
That’s fine. It’s “ generally accepted practice “ to renew struts in pairs, so once done, drive it around a few corners to get a feel for any asymmetry in handling. Tough times require these choices.
It’s not dangerous if you drive it like an adult. If you do go the shop route, you might get some upsell about how only doing one will make your car explode.
- gnalan
Since the strut is pretty much bottomed out at this point I'm sure the handling will improve once it's replaced, and it'll be safer than it is now.
- Has thanked: 987 times
- Been thanked: 1077 times
gnalan, I agree with what everyone else has said. I checked and I do have a decent boot also.
- gnalan
I haven't had a chance to pull the wheel off and check everything that's been suggested yet. Should I just go ahead and pull the strut assembly out and give it a good look over, or is it something that can still be done with it on the car?
Just curious, volvolugnut, where are you located?
If you take it off you will, of course, not be able to drive until you put it back on. Personally, I would wait until I had parts before removing the strut assembly.gnalan wrote: 01 Aug 2020, 13:34 I haven't had a chance to pull the wheel off and check everything that's been suggested yet. Should I just go ahead and pull the strut assembly out and give it a good look over, or is it something that can still be done with it on the car?
I am in Oklahoma. Too far for a road trip. Is Circleville the place that has a big pumpkin festival?
- gnalan
Yes, Pumpkin Show. Unfortunately, they canceled it this year because of COVID-19.volvolugnut wrote: 01 Aug 2020, 13:42 I am in Oklahoma. Too far for a road trip. Is Circleville the place that has a big pumpkin festival?
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
I have an old (functional) LSM for a non-front-fog light equipped P2. Let me know if you still need one.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 2713 Views
Last post by YYC850
- 29 Replies
- 4124 Views
Last post by foggydogg
- 1330 Views
Last post by volvolugnut
- 642 Views
Last post by rcherry506
