OKAY. I held off posting until I changed the oil in the XC90. I also put a fuel system cleaner in the tank with premium gas. (Then I went out of town on a trip and just recently got back).
So, just my luck, no more running rich on bank 1 and 2.... now I am getting the OPPOSITE codes. Running lean on banks 1 and 2. The car starts right up and does not act as if it is going to shut off and moves into low idle just fine. There is a barely noticeable delay in acceleration now and a very slight rough running.
I will post the actual codes and a video when I get a change. Any ideas? This see-saw game is killin me. :""D
Hard to Start After DIY Work
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
That can happen if there wasn't a reset. That's where you can check the long-term fuel trim to see what it's doing. It might take more miles to re-learn.
So, clear codes and see what happens as long as it's running well.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
miley
- Year and Model: 2009 XC90
Just an update for any interested and if anyone is having this issue in the future and needs reference:
Volvo ran fine but the codes never cleared. Last week my wife had the #2 ignition coil fail while driving on the interstate and had it towed to our shop.
My mechanic put a used coil in to get me home, gave me the failed coil, and instructed me to buy a new one online. It just arrived today so I will install it now. He was under the impression that the lean issue was due to the coil... I don't know about that, but he has always been a great mechanic and honest so we will see!
So I have had enough of chasing fuel system issues with this SUV that I love otherwise.
Going to get ready to sell it and get a 4WD Toyota or Lexus SUV for the wife. I bought new headlight casings for the Volvo. Going to install those then I need to replace or fix the condensation in the lower passenger taillight.... then fix or replace the stupid anti-skid sensor since that light is up on the dash. THEN have a TPMS sensor replaced and it will be GTG.
Think I'll buy a late 80s early 90s Volvo station wagon for fun. They can't be a headache to work on like my poor XC90.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Miley,
I own two 3.2s with the same engine as your XC90 both are over 130,000 miles and I plan to keep both to 300,000 or more.
If you really like your XC90 I can help you to fix it.
If you are selling no matter what then no need to read the rest of this post.
The first thing I would do is
1. replace the thermostat (they fail around 10 years and can cause coil failures and strange running problems)
Let me know if you replace the thermostat and I will post more suggestions
Thanks
Paul
Thanks
Paul
miley
Paul
Thanks so much. The decision to sell or not will ultimately be up to the wife, but since I will most likely be selling private I would like the car to be in the best condition I can make it.
I’ll replace the thermostat.... I just looked on eBay and found this:
https://www.ebay.com/itm/Thermostat-Hou ... 890.l49292
It says thermostat housing. Is this sufficient?
- pgill
Miley,
The Thermostat is very complicated. (don't buy an eBay part)
I wouldn't trust anything except a Thermostat from Volvo or from Land Rover.
The 3.2 is your XC90 was built at a FORD factory in the UK (Land Rover and Volvo were part of the Premier Automotive Group under FORD)
The only difference between the Land Rover and Volvo part is the Box (and Volvo wants more money for the part)
LR006071 is the Land Rover part number (I installed the Land Rover part on my S80 and LR2)
In the past I've bought from Tampa Land Rover parts
If you order over $99 the shipping is free
https://parts.landrovertampa.net/search ... h=LR006071
Just add something else to the order to get to $99 (the Thermostat is $96)
The Volvo part number is 31355151 (I would only buy a genuine Volvo part or Land Rover part)
This thread shows what needs to be removed.
Note: the XC90 may have more room and you might not need to remove the intake manifold
https://www.freel2.com/forum/topic32245.html
You will need to drain the coolant so make sure that you have the correct coolant
If you are going to remove the intake manifold let me know and I will make some suggestions of what you should do at the same time.
Good luck
Paul
Good luck
Paul
miley
Hey Paul, after a suggestion from another member in my other thread, I have a VCX Nano en route to help me diagnose my Anti Skid Service light. Should I hold-off on the thermostat? Will the VCX device help me more specifically diagnose this running lean issue?
The check engine light is back on after a bit of driving. So, I guess the mechanic was wrong about the ignition coil being the issue.
Thanks!
- pgill
Miley,
I would still change the Thermostat. (they only last about 10 years and your XC90 is ~12 years old)
Don't forget to take a picture of the broken Thermostat and post it here.
The VCX Nano will help.
The Anti Skid is a Haldex issue.
I will post a you tube video if I can find it.
Good luck
Paul
Good luck
Paul
- 932 Views
- 764 Views
Last post by Andrew Vanis
- 992 Views
Last post by sjbz2
- 655 Views
Last post by 93Regina
- 3088 Views
Last post by misha
