The Resurrection/Insurrection of GrunHilde - 1998 V70 NA M56 421 Green
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
abscate wrote: 28 Sep 2020, 15:17 Its perfectly acceptable to use wooden cribbing to prevent the seats from falling onto the pavement here. The fancy people even use pressure treated cribbing to show off their wealth.
I really appreciate these kind of tall tales where they start with something doubtful and suck you in to the next lines.
volvolugnuty
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
When I was 17, I had a '65 ford pick-up that had rusted out along the cab mount on the passengers side. Popped right up through the floor. So 3/4" plywood for the floor and Pressure Treated 2 x 4 wedged from the frame up to the top of the fender well. Held in place with a cable and turnbuckle. Fully adjustable :wink:
1999 V70 GLT
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
This is why I MVS.
Has thanked: 1611 times
Been thanked: 4072 times
Sveedy wrote: 28 Sep 2020, 18:34 When I was 17, I had a '65 ford pick-up that had rusted out along the cab mount on the passengers side. Popped right up through the floor. So 3/4" plywood for the floor and Pressure Treated 2 x 4 wedged from the frame up to the top of the fender well. Held in place with a cable and turnbuckle. Fully adjustable :wink:
For Volvo it’s 19mm plywood and 5x10 cm lumber of course
Fixed fuel leak with hose between rollover valve and tank
New fuel filter
FIred up and got hot - no coolant leaks!
ALternator light off, but system voltage low and eventually coded for same. Battery down to 9.4Volts
ALternator is probably pulling massive current through shorted diode, have spare.
No leaks or drips, ran gears up through 3rd to clean up rotors a bit.
30 minutes run time
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
abscate wrote: 29 Sep 2020, 09:13 Fixed fuel leak with hose between rollover valve and tank
New fuel filter
30 minutes run time
Heck of a find, for sure =)
2023 Lexus RZ450e -66k
Has thanked: 2209 times
Been thanked: 1852 times
Major progress and some good signs of 'positivity' with exception of the alternator of course!
Pulled the alternator today and found worn out brushes with no contact on one.
New brush holder/regulator ordered for $24 !
1 197311 520 for alternator 9162683
MVS could have a new sticky thread for cheapest ride from spare parts pile. Of course, moderators would not be able to participate.
volvolugnuty
850oldschool
How about a "rust porn" forum category?
