From VIDA (their bold fonts):
Filling and checking the oil in the Active on Demand Coupling:
Use correct oil
Volume approx. 650 ml.
Fill oil up to the filler plug. Suck out 0.1 l oil.
Caution! If the AOC (Active on Demand Coupling) has been replaced with a new one, the car must be driven carefully in tight circles in both directions and then driven for a few kilometres after the oil is filled. Top up the oil level and check again according to the above.
So I will "drive it carefully in tight circles" in both directions" because why not at this point and then fill it to top minus 100 mL, thanks for the heads-up.
Prop shaft and Haldex service '07 XC70
- Has thanked: 292 times
- Been thanked: 765 times
Re: Prop shaft and Haldex service '07 XC70
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1497 times
- Been thanked: 3810 times
What are you doing with that used Haldex oil?
-scot850
-scot850
Changed the rear differential fluid with Valvoline 75w-90 synthetic, same thing I used in the angle gear.
Withdrawing the old oil was really slow, I used a 60 cc syringe and thin, flexible plastic tubing. Had to shove the tubing down into the box with pliers. Don't use anything brittle that may break off inside the rear diff case. Took about 4 minutes to fill the syringe each time; I propped the plunger back with a socket and extension and walked away while it was filling.
Oil was dirty! See pics.
Was able to remove 425 mL total, replaced same amount. Replacement is much easier of course, used a large bore tubing on the pointy bottle end and squirted it right in.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Just a followup on finalizing the oil level in the final drive i.e. the rear differential. The fluid is different (75w-90 gear oil for the differential) but VIDA's fill instructions are similar as for the AOC:
Volume approx. 500 ml.
Fill up to filler plug level. Suck out 100 ml.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Update regarding swapping the DEM pump without completely removing the propshaft:
I swapped the pump this week on our 06 S60R and instead of pulling the propshaft completely, I lowered the exhaust slightly and let the propshaft sit on the exhaust. This change simplified and shortened the job compared to the other times I've done this task.
Car ready for Haldex service: (1) remove DEM, remove the T25 Torx screw attaching the front O2 sensor wire to the exhaust.
(2) support exhaust with a jack, detach three rubber exhaust hangers at rear, lower exhaust slightly, support it with the muffler about 10 inches off the ground.
(3) do *not* loosen the two bolts holding the center carrier bearing. Instead, completely drop the bracket holding the center bearing by removing its 4 bolts underneath (10 mm socket). The drive shaft will now flex in the center, allowing you to
(4) remove the 6 front socket head cap screws; release the front CV using an air hammer and pointy bit
(5) remove the 6 rear socket head cap screws; release the rear CV the same way
(6) now pull the front CV out of the angle gear and maneuver it upward. Pull the rear CV out of the big rusty flange and slide the whole assembly (propshaft+bearing+bracket) slightly forward. It will drop down and rest on the exhaust.
(7) zap the center flange nut off with 24 mm impact, remove and replace Haldex pump and filter (4 mm hexes), refill Haldex fluid; all as described elsewhere.
(8) put it back together, enjoy AWD (and ABS) again.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
0) cut down a 12 inch oak and fabricate four jack stand safetieserikv11 wrote: ↑03 Aug 2025, 00:43 Update regarding swapping the DEM pump without completely removing the propshaft:
Car ready for Haldex service: S60R on stands.jpg
9) burn wood in a solo stove and make pizza
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 113 times
- Been thanked: 262 times
About the only reason to remove the shaft from underneath the vehicle is if you were to clean and repack the CV joints fore and aft. Too bad they didn't make the pump removable without having to take the propshaft out. You'll notice that all the really dirty fluid only comes out when you remove the pump from the bore.
2003 XC 70 (sold)
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
I’m underneath (‘04 XC70) looking up at this because the exhaust is hanging to replace the sway bar.
Does the driveshaft flange have to come off to access the filter and change the fluid? I see a video where the guy maneuvers his hands around the driveshaft flange to get to the filter cover.
Are the filter cover bolts hard to get at without a wobble?
Thanks -
Thanks -
- Blacklab467
You can get the filter changed without removing the shaft or flange, I thing its a M4 or 5 Allan key. The flange has to come off for pump removal. Filter cover bolts are easy, use a hex key.
2003 XC 70 (sold)
- BlackBart
I see in that other thread Pete said:
“As I’m sure you can now see, the filter can only be replaced if the driveshaft is out of your way.”
That made me think that’s a bit involved for the time I have.
- 3686 Views
Last post by rollin_home
- 782 Views
Last post by warcraftjunkie
