2004 XC70 oil pan condition
arrrxivvv
Year and Model: 2004 XC70
Has thanked: 16 times
Been thanked: 10 times
Post by arrrxivvv »
Thanks, I don't think I ever drive hard. Hopefully I can keep it running for a long time.
04 XC70 206k
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
arrrxivvv wrote: 26 Feb 2021, 10:29 Thanks, I don't think I ever drive hard. Hopefully I can keep it running for a long time.
To drop this oil pan (2004 XC70), did you have to move anything like power steering lines or AC lines, or loosen the subframe or raise the engine etc? Or does this one just drop down and wiggle out once you remove all the bolts?
arrrxivvv
Post by arrrxivvv »
There's a fuel line bracket bolted to the top of the oil pan, but other than that nothing needed to be removed, just wiggled out.
Removing the transmission torque mount probably helps, as its bolts are kind of bulky.
I'd say it's pretty straightforward.
04 XC70 206k
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Smoky Yunick, master mechanic, racer, and owner of 'The Best Damn Garage in Town' had a rule of thumb for oil pressure - you need 10 PSI for every 1000 RPM.
Detroit Diesel 2 stroke engines were known to have very low oil pressure at idle - 8 to 10 PSI. It did not reduce their useful life.
arrrxivvv
Post by arrrxivvv »
Cool.
I wonder what's the hot idle oil pressure psi most people see.
Is it true that 20 psi or above is normal?
I couldn't find a lot of data here. Probably because if the car runs great people wouldn't bother measuring the pressure.
04 XC70 206k
arrrxivvv
Post by arrrxivvv »
Update 5000 miles later, the engine is still fine, oil lamp goes off quickly after startup
04 XC70 206k
