Coil pack melting
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
StephenG wrote: 12 Jan 2021, 10:45 I have noticed the heat spreads from the end nearest the connector plug, but still no idea why. Next thing to check must be the ecu.
Excess heat indicates excess current.
1. Have you checked for heat with the coil pack disconnected?
2. Have you checked the wiring for shorts?
3. Short in connector? Sometimes the connector walls between the pins acquire a defect.
4. Are you using IR thermometer to pinpoint the source of the heat?
Active
Past
Has thanked: 1610 times
Been thanked: 4065 times
RickHaleParker wrote: 14 Jan 2021, 05:01 4. Are you using IR thermometer to pinpoint the source of the heat?
+1000 points for this, Rick
StephenG
Year and Model: 2004 c70
Post by StephenG »
Only gets hot when the engine’s running and the coil pack is connected. Wiring and connectors renewed- all ok. No shorts or breaks. Does need a thermometer, you can feel it with your finger as it spreads. Still to check, trigger wire coil pack to ecu continuity and find if wire 3 still has 7ohms to ground. Also must check if it gets excessively hot with the ignition left on but not running.
StephenG
Post by StephenG »
Hi Abscate and Rick, looked a bit more this evening b4 it got too dark. Checked the signal wire continuity, all ok. The coil only gets hot when running and the 7 ohm reading from 12v feed to ground is on the feed side to the fuse so unlikely to be relevant. Next question- will the coil pack get hotter with the signal wire shorted to ground or if permanently live. Answers on a postcard....
StephenG
Post by StephenG »
Have got a spark on all 5 plugs, though on the toasted coil it was weak/erratic, but ok with a good coil. Can’t run it for more than a few minutes as it will melt and I’m running out of coil packs. Most of the coils I’ve used have been second hand,
RickHaleParker
Your Wire colors and test points?
Active
Past
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
could a faulty spark plug be to blame? i wouldnt be putting new coils, use the old ones to test. Remove the plug and inspect inside the chamber
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
darrylrobert
could it be dry firing, ie not fuel? that might cause it to heat up? You may need to check the wiring for continuity.
StephenG
Post by StephenG »
Hi the diagram is close, my car doesn’t use pin 2, as it’s a turbo, and my trigger wires are A31,30, 50,52,50 respectively from no1, there are lots of different combinations of trigger wire nos. on various sites, I found my version on Matthewsvolvo so assume it’s a correct line up. I don’t think it’s dry firing because it overheats far too quickly. Last evening I found the crank sensor has been put in place with silicone so I have to sort that, but that should not affect one coil pack, unless someone knows otherwise
Wait
What is the resistance of number 3 pin on the connector to ground? That’s on the secondary side of the coil.
