2003 v70 stalls very often. Parts replaced. Need advise
antoniveb
Year and Model: 2003 V70
Post by antoniveb »
OK. MAF replaced. No Check Engine light. Power feels OK.
Car still stalls. Not often. Like it's back to the state of 2 years ago when stalling had started.
When I was replacing sensor I noticed something new: static electrical sound from the board near battery+ connection. Unplugged and plugged back all the relays. Couldn't understand which one is making it.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Show us your new fuel trims? Does it stall while idling?
antoniveb
Post by antoniveb »
Not stalling while idling.
freeze frame:
SHRTFT1 -3.1
LONGFT1 -0.8
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Those values look good
BMW 540i 2002
S70 Base 2000
vtl
Post by vtl »
Looks good.
If by stall you mean the engine dies and you have to restart it, it's one of:
- throttle body - VIDA/DiCE can do a swipe test
- fuel pump - you have replaced it
- ECM looses the crankshaft position sensor (CPS) - trace wires, check the sensor and it's bracket
- bad electrical connections at ECM - taking that out and spraying with electric contacts cleaner would help
antoniveb
Post by antoniveb »
I do not have VIDA/DiCE can I go around?
Are other cars like Honda and Toyota as demanding as Volvos?
I've always believed in Sweden though I feel like I'm in Denmark :(
vtl
Post by vtl »
:-D
Yeah, P2 is not very reliable after 120-150k miles. Ford/Geely I don't count as Volvo, so my latest addition to the fleet was new Tundra. No bells, no whistles, V8. I managed to break it where 05 XC70 was doing OK, so I have mixed feelings ;)
vtl
Post by vtl »
The most comfortable vehicle in my life was 02 V70.
antoniveb
Post by antoniveb »
Yes. I love the vehicle too.
But it looks like I initially bought it with this problem.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Codes:
P0113#12
intake air
Temperature sensor 1
Circuit High Bank 1
Temperature sensor would cause the issues your are experiencing. If a wrong temperature is provided to computer it will adjust the air/fuel mixture ratio and all xxxx can happen.
I am not sure if unplugging it will put the system in a closed loop, but cannot hurt to try for trouble shooting. Worse case scenario it will code which you can clear. Just don't be dumb about it if it works as you are not fixing anything only troubleshooting and you are taking out an important component and close loop is not optimal and can harm the cats in the end.
