Were you looking at the digital or analog signal? Irregular voltage waveforms, or erratic ones and zeros?abscate wrote: 13 Aug 2021, 06:37My personal favorite. "I just picked up this sweet Volvo for $500, the seller said all it needs is an abs module". When I hear that I know the car is a $2k FCP order away from being just OK. It's also loaded with butt connectors, zip ties, rtv all over and a mirror full of air fresheners to cover the smell of 500 cartons of cigarettes.![]()
I got my butt kicked in a BMW E83 this Spring
With a new job in NYC SWMBO favourite non-Volvo car had a nice habit of kicking into limp mode 20 minutes after getting to highway speed. Nasty
I chased ignition and fuel and finally found a rusty tone ring on right rear , which was shutting off the ECU. Not a single code was set. Finally tracked it down with real time wheel speed data , seeing noise on the signal on that wheel.
It's not always the ABS module
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
- Has thanked: 1614 times
- Been thanked: 4078 times
Digital waveforms on a scanner. The data is analog but it’s sampled at 1hz or so
The right rear wheel showed a lot more modulation, about 5% of the signal than the others. New tone ring cleaned it up and eliminated the loss of power issue
850oldschool
Were you scanning that through the OBD2 port?
Yes, via an AUTEL 812? Scanner with a module for BMW specific codes
