Proven method to remove an engine oil stain on a cement driveway
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
cn90 wrote: 12 Mar 2024, 09:42 Try Purple Power...
But again, I minimize the use of chemical if I can to avoid
polluting this planet.
Most of the time, DW soap, some water and the sun works...
/\ this/\
I’ve had success with a concoction of dish soap and simple green (or purple power) and a stiff bristle brush. Lots of soak time, repeat scrubbing, soak and repeat. Eventually it’ll pull the oil out of the concrete.
08 C702.5T (sold)
The non-Swedes:
wahiddd
Year and Model: 2001 S40 2.0T
Post by wahiddd »
I had the same issue not too long ago, and I tried everything to get rid of it. Pour-N-Restore, DW soap, OxyClean. But nothing worked. Eventually, I tried pressure washing. Although it seems the most obvious method, I left it as the last one, and it's the only that did the job. I don't have a pressure washer, so I called a local service, Pressure Washing Oahu. Fast and effective results. In about half an hour, the whole driveway was clean, and not even a trace of that oil stain.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
baking powder and solvent mixed into a paste (same as K2R)
spread it on, let it dry out a bit and hit it with a heat gun to boil the oil into the baking powder, sweep it away.
Works good on wood too.
Has thanked: 1610 times
Been thanked: 4068 times
Buy more Volvos and park over the stain
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
abscate wrote: 14 Mar 2024, 02:56 Buy more Volvos and park over the stain
He has to drain them first and perhaps wrap water oil tight.
NoraSilas
Year and Model: 2012 S60
Post by NoraSilas »
Hi, I understand your pain! I also had big oil stains on my cement driveway, and it was really hard to remove completely. One thing I found helpful is using a strong degreaser and letting it sit, then scrubbing with a stiff brush. Also, if anyone needs help with planning or repair costs for driveways like this, there are companies providing concrete estimating services in USA that can give accurate estimates before starting cleaning or resurfacing.
