Scraping / Tapping 08 S60 2.5T
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
08s60
Year and Model: 2008 S60
Re: Scraping / Tapping 08 S60 2.5T
Post by 08s60 »
Well, after looking at other cars and seeing the stupid prices on used cars I began looking at an engine swap. I’ve located a 110k engine out of an 07 S60 for $1,000. Of course, the timing system will be replaced on this motor and PCV hole inspected and cleaned before installation.
I have a mechanic looking at it and will have a quote to do the swap on Monday. Any ideas of what I should expect for time and cost to do the work?
DonnVa
Year and Model: 2005 XC70
Has thanked: 21 times
Been thanked: 60 times
Post by DonnVa »
I can’t give you any time or cost info, but I would suggest that you have the rear main seal replaced on the donor engine as well. It’s a cheap seal that would cost a lot to replace after it’s all together.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
vtl
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Buy Volvo RMS, not aftermarket, plus new flywheel bolts.
I did engine+transmission swap in a ~week, working a few hours at evenings, combining it with kids diapers, etc. With the lift the whole subframe can be lowered and you'll have better access to everything, which speeds things up quite a bit. If you go this way - replace the subframe bushings as well.
