I'm on a road trip right now, and noticed a noise coming from the engine compartment. It sounds like metallic scuffing sound, and does NOT vary directly with engine speed. However, increasing engine rpm does make the sound fade away, so I'm thinking it's like the turbocharger compressor wheel dragging on the housing. Is this a likely cause of the noise? If so, any experience on how long a car can be driven in this condition? I'm hoping to return home (~ 400 miles) tomorrow afternoon. With the engine under load at even 30-40 mph, the sound is nearly gone, and not noticable at all at highway speeds.
I'm not concerned with saving the turbo for rebuild, as I have a guy with a couple parts cars that could supply a used turbo when I arrive home. I'm just hoping for no surprises on the return trip. Any thoughts would be appreciated!
98 V70 AWD LPT - metallic scraping noise
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
How old are the timing belt parts?
If it were anything to do with turbo wear, there would be lots of smoke and poor performance.
Post a video of the noise if you can.
renns
Timing belt, water pump, and all pulleys were replaced about 50k ago. The sound does not change directly with RPM either, which I would expect would happen with any direct engine-driven part.
renns
A quick update: The return trip was uneventful, and at the stop for gas after 3.5 hrs driving, the noise was gone. The symptoms appeared after the car was driven and parked in an area of tall grass/weeds at an off-road racing event we were attending. I'm suspecting now that some debris from that parking area was caught somewhere temporarily, causing the issues. All dreams of water pump or turbo swap at the side of the interstate were for naught. I wish all problems would heal themselves in this fashion!
