1994 850 HVAC Question
Has thanked: 2200 times
Been thanked: 1852 times
Thanks Rick. Memory is not as good as it used to be but occasionally surprises! Thanks for clarifying!
Found an 850 version of the ECC but it is Canada/EU version in degrees C. Part number 9166549. I'll have to look up if this is an early or late car. It may be the same but with the C rather than F front plate.
Curios as according to this Volvo dealer web-site (and Volvowebstore) they both say the part is NLA but in the part number I gave above they say it fits 93-97:
https://parts.volvounionville.com/p/428 ... 66549.html
I have no idea where this came from as it has been in a box for a long time. I think I bought a bunch of parts from a guy wanting rid of all his spares and this was in it.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
scot850 wrote: 01 Nov 2021, 17:14 but in the part number I gave above they say it fits 93-97:
You can use a new one in a older model IF you change the wiring harness also. The new wiring harness is for the D+ supply.
In VIDA set vehicle selection to 1997 850. Then go to: Information/ Product Specifications / Other / Body and Interior / Climate units / Table of control modules and power units.
There you will find a table of what works with which model years, chassis numbers ... power units.
Maybe the 850 guys should figure out how to emulate the 850 ECC on a Development Board so be used as a PCB replacement.
Active
Past
rsmigel
Year and Model: 1994 850 Turbo
Been thanked: 2 times
Post by rsmigel »
So my unit is a 9144256. Looking a little further below in the chart I see a 1995 unit 9166550 having a "size change." Hmm… that doesn’t bode well for a replacement. Yet, going through volvopartscounter.com shows the 9166550 when searching for my 9144256.
Is the -550 a direct replacement for the -256?
If you pull your unit out (have you done this before?), you can measure the front face plate dimensions and width and depth of the rear metal casing. I can compare with the one I have part # 9166549 W637K. It is a celsius face plate but the dimensions should still be correct to that of a F version. Rick did mention a wiring change above.
rsmigel
Post by rsmigel »
I’ll pull it out again and measure everything. It’s easy to do. That would be a good reference to archive.
My -256 has the D+ cable so I wouldn’t think I’d need a modified harness as I’d only be getting a newer unit if I can’t match my S/N exactly.
RickHaleParker
rsmigel wrote: 07 Nov 2021, 05:40 So my unit is a 9144256. Looking a little further below in the chart I see a 1995 unit 9166550 having a "size change." Hmm… that doesn’t bode well for a replacement.
It is size change front panel. No indication of any change in size of the ECC. This need some more investigation.
Your ECC is a unit group #6. Which means you have the D+ supply modification. That rules out unit groups 1 - 5.
Active
Past
Has thanked: 1610 times
Been thanked: 4065 times
Celsius scale
-40 friggin cold
-10 fresh air
0. Ski time
10 civilized
20 windows open
25 AC
30 frigging hot
RickHaleParker
abscate wrote: 07 Nov 2021, 11:39 Celsius scale
-40 friggin cold
-10 fresh air
0. Ski time
10 civilized
20 windows open
25 AC
30 frigging hot
-273.15 degrees celsius is 0K.
Active
Past
