This is our 3rd car...doesn't get used much. Been sitting in sub zero weather for a month w/o starting till today. It struggled at first but settled down...then noted the blower was dead but the HVAC is lighting up...have not had time to put on Vida Dice yet.
30amp fuse is AOK
I've replaced the motor twice in 5 years on this car...always el cheapos that work fine but I replace due to squeeling bearings on turns.
I know on my Saab when the resistor would go it would just leave the fan on 100% full speed...so doubt that is it. No smell.
Anything to try or just a DOA fan?
2001 V70T5: Dead HVAC blower...
carboncow
- Year and Model: 2003 XC70 2018 S60
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Check the electrical connector at the fan for loose/dirty/recessed pins.
I think VIDA/DiCE can read the amperage draw by the blower motor also. If it stays at zero amps, then I would try hard-wiring the B+ to the blower motor through some resistance (like a headlight bulb in series) - it could be that the blower's speed control is at fault this time, and not the motor itself.
If you are below freezing, condensation and/or debris could be interfering with the squirrel cage
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
carboncow
Regent...good call! I put the car in the heated garage for about 5 hours and it the fan started right up. Something was frozen!
Not saying it couldn't have been the speed control but my experience had been the enginners design them to all fail at 100% on so the end user has at least something pushing heat/cool if there is a failure.
So I thought your 2nd idea sounded spot on and I think it was. Good lesson learned and always something new even after 25 years of DIY wrenching!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- regent
I am thinking worn or 'hanging' brushes (don't know how many run-hours your blower has). The brushes probably 'shrank' even further in the cold and could not reach the commutator.carboncow wrote:...I put the car in the heated garage for about 5 hours and it the fan started right up. Something was frozen!..
The biggest issues in our old cars are caused by electrons: As the car gets older, they do too, and then they get tired and eventually become a lot slower...
Slow Electrons + Extreme Clod = Loss Of Functionality
2015 BMW 335i
2015 BMW 335i
- 1167 Views
Last post by oragex
- 485 Views
Last post by thorv70t5
- 5971 Views
Last post by RaynormusT
- 1391 Views
Last post by mf70
- 17 Replies
- 1927 Views
Last post by Botbasher
