Most o-ring material is resistant to oil/grease so you could get by with a petroleum based grease but would be better to use a silicone based grease. If you have any dielectric grease this would work too.02V70 wrote: 15 Apr 2022, 11:42How much does the lube base matter? I don't have anything with a silicone base, but I have lithium and petroleum.vtl wrote: 06 Apr 2022, 17:16 This is what you want, in fact. When it gets in, it won't leak for another 10-15 years.
Add some silicone lube and try to push the pipe as square as you can. I didn't have any problems, had to do it twice (in two cars), went in without much hassle.
Coolant leaking from heater core.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I got the clips out, but now that I'm reconnecting the pipes, it seems that the o-ring is keeping it from going in all the way, and I can not get the clip for the top pipe to even get in the holes, as I can't fit my hand in there. Is there a way to get the bottom pipe off so I can put the clip in?
2002 v70 X/C 288k miles
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
I cut the zip tie that holds both those pipes up high under the dash. Had to buy long pliers, like 1.5 foot long. After that the pipes had much better maneuverability, and I had zero problems reconnecting everything back.
I think I may have used the same pliers to push square against the lip on the pipe.
- 02V70
I did it, and no more leak!
If anyone in the future has problems getting the pipe with the o-ring in all the way, get fully out of the car, then reach in and press your hand against the pipe, then lean your body weight on it.
- 11 Replies
- 9818 Views
- 751 Views
- 5071 Views
- 1120 Views
Last post by theWIFES_S70
- 32 Replies
- 17681 Views
Last post by sleddriver
