Coolant is leaking quite a bit from where these pipes meet the heater core.
How would I fix this? Does the heater core need to be replaced? What If I just slather a bunch of rtv on it?
Coolant leaking from heater core.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Likely the o-rings, it's a fairly common problem as the o-rings harden with age. Replace with OEM parts, the o-rings and retaining clips. It's not a fun job working under the dash but at least it's an inexpensive repair. It's possible it could be the heater core but much more probable it's just the two o-rings.02V70 wrote: 05 Apr 2022, 17:12 Coolant is leaking quite a bit from where these pipes meet the heater core.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I found the o-ring and retaining clips on fcp Euro. For the O-rings, they have OEM, and Geunuine Volvo. Since the OEM ones are 10x cheaper than the Genuine ones, is it fine if I get the OEM ones?
2002 v70 X/C 288k miles
- Been thanked: 504 times
- Time to replace the heater core itself, if you have the budget...
- I use only genuine Volvo O-rings.
- I wrote the DIY for my 2005 XC90 in the XC90 section...
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
When I replaced the heater core in our (now gone) 2005 S80 I re-used the original retaining clips as they appeared to be better quality/better fit than the clips provided with the new heater core.
As a side note, I replaced the original leaky core with a no-name unit from the local auto parts store. About a year later it started leaking. Ended up replacing it again with a Behr unit which I believe was OE.
1+,
- Metal clips should be re-used.
- O-rings: Volvo genuine only, it is not that expensive.
- IIRC, the Behr heater core was made in France...
https://www.matthewsvolvosite.com/forum ... hp?t=82726
- 02V70
I also got the Volvo genuine hose clips as the many reviews for the product stated that they bent the original ones taking them out. When I do change the o-rings, how much coolant needs to be drained, and where do I drain it from?
- 02V70
Yes. It will be a very helpfull tutorial, thank you.
You did not mention draining the coolant, you only said to put a plastic bad underneath to catch some spilled coolant. So do I not have to drain anything?
No need to drain radiator or cooling system.
Just replace what is lost during the job.
Not much loss, maybe 1/4 gallon...
- 11 Replies
- 9902 Views
- 760 Views
- 5099 Views
- 1126 Views
Last post by theWIFES_S70
- 32 Replies
- 17908 Views
Last post by sleddriver
