You need a working keep alive for 2003 car. And cracker does not support so called CEM-B units.
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
You need a K-line keep alive on a CEM-B only if your connected to the CAN diagnostics ports. Connected to the other CAN ports and K-line keep alive is not needed. The reason a CEM-B disconnects from the J1962 connector when not in use is because unlike all the other CEM types, CEM-B is a end node. If the J1962 connector where to remain connected, the internal terminating resistor would not be at the physical end of the CAN bus.alevol wrote: 22 May 2022, 01:25 You need a working keep alive for 2003 car. And cracker does not support so called CEM-B units.
No successful crack algorithm for the CEM-B.
Active
Past
Past
rednasdees
- Year and Model: 2004 V50 2.4
Hello,
Great thread all off you guys, i read almost evrything that is on here
Would any of you be able to help me set up the software, because i have never used a teensy before :S ?
I have a teensy 4.1, with a mcp2515 for the canbus
i intend to use it on a volvo v50 from 2004
Thanks in advance !
Thanks in advance !
rednasdees
oke, can you direct me to a good quality can tranceiver ?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It is mentioned on schematic: https://github.com/vtl/volvo-cem-cracke ... ematic.png Others may work as well, like Bosch CF160.
oscilloscope
- Has thanked: 27 times
- Been thanked: 11 times
very cool thread , although exhausting too read through approx 200+ posts. , to add this application needs to be able to evolve into being able to synchronise the ecu & cem on various versions.
Hi,
Im having a problem with P2 brick cem cracking.(part nr.8688513)
It wont read part nr or go to prog mode..
Have tried P1 and P2 CEM-L and then it works fine..
CPU Maximum Frequency: 600000000
CPU Frequency: 180000000
Execution Rate: 180 cycles/us
PIN bytes to measure: 3
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
Can't find part number on CAN-LS, trying CAN-HS at 500 Kbps
CAN high-speed init done.
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=cb 50 b9 f0 00 00 00 00
Unknown CEM part number 0. Don't know what to do.
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
Resetting all ECUs.
- 9947 Views
Last post by RickHaleParker
- 10321 Views
- 27 Replies
- 31690 Views
Last post by cn90
- 12163 Views
Last post by jonesg
- 7099 Views
