Ok took the plunge and bought it.T5Luke wrote: 01 Aug 2022, 16:29 I have both and on both of them the same code works. So have fun with it...
Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
oscilloscope
We have lift off. Its arrived
When My son goes to bed ill have a good look at it.
jaywats
- Year and Model: 05/06 s60r
- Has thanked: 14 times
Hey I'm stuck on the same thing too, it's next on the list. can you share what needs to be changed on CEM-H 30765148?thanks!ZRimaZ wrote: 12 Jun 2022, 01:12You have to remove alarm in cem config and after - disconnect siren. If you have cem flash, send it to me, i'll remove alarm from config ( in case if you do not know, how to do itvtl wrote: 11 Jun 2022, 16:49 It seems my repaired alarm siren is again leaking and again draining the main battery. I want to throw it away, the car is never locked anyways. Don't what to see the immobilizer warning message on every start, though. What are my options? Is it a bit toggle in CEM's car config?
I may have finally put the whole pin cracking project at use![]()
P2 - 06 S60 2.5 || 05 S60 2.5 || 02 S60 2.3
oscilloscope
folks , so I'm trying to locate the vin within this CEM and i can't find it at the typical location
- 9286 Views
Last post by RickHaleParker
- 9240 Views
- 27 Replies
- 28624 Views
Last post by cn90
- 10720 Views
Last post by jonesg
- 5857 Views
