Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
Has anybody verified that this will work on both versions of the P2 CEM? P2 CEM-H (1998-2004) and P2 CEM-L (2005-2016).
Active
Past
Past
- RickHaleParker
I have the hardware sitting in a box ready for assembly but been busy playing with my Next Generation Amiga.efe09 wrote: 28 Jan 2021, 16:54 Hi RickHaleParker,
have you already tested this kit (Teensy 4.0 + MCP2515+CY1076) in the car?
My attempts were unsuccessful![]()
Which version of the software do you have loaded? VTL's version or Mark Dapoz's version for the Teensy 4.0 onboard CAN.
Active
Past
Past
- RickHaleParker
Here is the other version. Also on github: mdapoz /volvo-cem-cracker
Active
Past
Past
P3 Volvos CEM blocks are based on M32C processors as well. Could it be possible to use this algorithm to crack a P3 PIN code too?
With a prerequisite that it is known how to deal with the PIN ceed request...
- V702T5
- Year and Model: 2004
- Been thanked: 2 times
Hey Guys, first thanks for this unbelievable work.
I ordered now everything for my own CEM Cracking Module (Teensy 4.0 + MCP2515 + CY1076).
Im Driving an Volvo V70 II T5 (MY2005) with the CEM-L
Is there allready any Software to modify his own CEM Module ? (Like VDASH for P3 Volvos) or will i do need send my Cracked Pin Code to VDASH (to unlock my Car for Vdash).
I allready unlocked my Friends Volvo p3 with Dice + Vdash and deactivated his light und Pos0.
Sorry for my Bad English and Greetings from Germany.
With Regards
David
With Regards
David
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Timing attack can't be applied to P3. Worse, in some jurisdictions, like USA, it is not legal to develop an algorithm that will crack it, since its hash computation algorithm falls under DMCA umbrella. Though it is perfectly legal to build a your own thing based on P3 chassis and drivetrain, but replacing its proprietary electronic modules with your own.
Also, in my opinion, P3 and newer Volvos are soulless junk and not worth it. Volvo is not dedicated to build quality and "customer first" approach anymore.
paddy0174
- Year and Model: MY2005 XC90
- Has thanked: 1 time
You need to have the pin code setup in VDASH, which means, you have to crack it yourself or you send the CEM to D5T5 and get it cracked. Both ways end up in assigning your PIN in VDASH, before you can do anything.V702T5 wrote: 01 Feb 2021, 06:57 Hey Guys, first thanks for this unbelievable work.
With Regards
David
So if you have already ordered the necessary parts (unlike me...
German translation:
Der PIN wird in VDASH benötigt. Entweder Du crackst ihn selbst oder sendest das CEM an D5T5 zum cracken. Egal welcher Weg, ohne die PIN in VDASH hinterlegt zu haben, geht nix, leider.
Aber nachdem Du die Teile ohnehin schon bestellt hast (Im Gegensatz zu mir, leider
Volvo XC90 D5 AWD Summum MY05
Harley-Davidson Ultra Classic Electra Glide MY91 FLHTCU
- 9511 Views
Last post by RickHaleParker
- 9640 Views
- 27 Replies
- 29814 Views
Last post by cn90
- 11221 Views
Last post by jonesg
- 6324 Views
