You miss 60 can frames of data cause your cem is sending faster as your dice can capture the data.
You can press shift and right click in the dir where your exe is and open command line or powershell, (in powershell write cmd and press enter) then type in udsread.exe >log.txt
Enter pin code blind and press enter, wait till your dice stops blinkin and take a look in log file.
If that won't help, try faster computer or windows 7. I use one of the earliest mobile i3 devices and have no error reading the cems. My core 2 in xp also has no probs.
Vida CEM swapping
Thanks. I was running this on a Win 7 virtual box when I got those errors, but I was able to get it running directly in Win 10 now.T5Luke wrote: 21 Sep 2022, 04:17 You miss 60 can frames of data cause your cem is sending faster as your dice can capture the data.
But I still get an error, now it’s “ERROR 0” (see attached image)
Oh…sorry
Many thanks for all your help and your patience with newbies like me!
Edit: Final question (I hope
75 54 59 07 69 48
Divxet
- Year and Model: 2003 v70n
- Has thanked: 15 times
- Been thanked: 3 times
Thanks to T5Luke and his software i did succesfully clone my V70 MY2003 cem and changed the carconfig in the new second hand S60 MY2001 cem.
Everything is working as it should.
matija0610
- Year and Model: 2003 S60 D5
- Has thanked: 21 times
- Been thanked: 13 times
sorry for spamming, I haven't read the forum for a while, a lot of things have accumulated, I don't have time to catch up now..PontusLSE wrote: 21 Sep 2022, 13:37Oh…sorryI’m so used to errors now so the word “error” itself was enough to tilt my brain.
Edit: Final question (I hope). Is this the pin needed for vdash?
75 54 59 07 69 48
but, why do you need Vdash, if you have .bin ?
do you want to change something in the configuration?
matija0610 wrote: 21 Sep 2022, 14:52sorry for spamming, I haven't read the forum for a while, a lot of things have accumulated, I don't have time to catch up now..PontusLSE wrote: 21 Sep 2022, 13:37Oh…sorryI’m so used to errors now so the word “error” itself was enough to tilt my brain.
75 54 59 07 69 48
I am trying to figure out how to change the maximum speed (v-max?). This ECU is modified from before, so my idea was to use vdash to set the max speed and after that compare the bin with the change to the bin without the change, to figure out what parameters has changed.
matija0610
v-max is @4A106
possible parameters:
CHKSUM - 8bit SUM whole CONF Block @4A101 (you have to calculate this, if you change the configuration)
CHKSUM - config block lenght @4A100 (you don't touch that one)
- 9380 Views
Last post by RickHaleParker
- 9398 Views
- 27 Replies
- 29076 Views
Last post by cn90
- 10919 Views
Last post by jonesg
- 6032 Views
