Any progress?
Vida 2014D Times out 12/31/2017 23:59 Topic is solved
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
xHeart
Clean up and reinstalled VIDA/DiCE has worked.
prefuse07
- Year and Model: 99 S70 NA
- Has thanked: 6 times
I reinstalled over it, and it seems to install good -- I actually got to see VIDA monitor go from yellow to green. Did as per Rick's original instructions including waiting for the java update (which last time didn't happen).
Went to scan the car -- unfortunately, still get that '0' exception error, and this time, when I clicked on Diagnostics, it didn't even try to communicate with the car.
Any thoughts?
At this point, I think I am going to return my DiCE unit, and just give up, unless you guys have any other suggestions?
• 1998 S70 N/A
• 1999 S70 N/A
• 1999 S70 N/A
- RickHaleParker
- Been thanked: 980 times
Run Both DiCE diagnostics.prefuse07 wrote: 08 Dec 2019, 12:10 At this point, I think I am going to return my DiCE unit, and just give up, unless you guys have any other suggestions?
The standalone is in the Windows start menu under DiCE.
The second one is on the Vehicle profile page in VIDA under Dice Configuration.
Active
Past
Past
xHeart
Unless you have a device related missing driver, can you post a screenshot of Control Panel > Program and Features?prefuse07 wrote: 08 Dec 2019, 12:10
Any thoughts?
prefuse07
I did that, the results were the same as the screenshots I posted earlier, Interface test results in a fail, but all others pass. The Battery voltage does not go above 12.5 V.RickHaleParker wrote: 08 Dec 2019, 15:32Run Both DiCE diagnostics.prefuse07 wrote: 08 Dec 2019, 12:10 At this point, I think I am going to return my DiCE unit, and just give up, unless you guys have any other suggestions?
• 1998 S70 N/A
• 1999 S70 N/A
• 1999 S70 N/A
prefuse07
xHeart wrote: 09 Dec 2019, 07:58Unless you have a device related missing driver, can you post a screenshot of Control Panel > Program and Features?prefuse07 wrote: 08 Dec 2019, 12:10
Any thoughts?
Here you go:
• 1998 S70 N/A
• 1999 S70 N/A
• 1999 S70 N/A
- RickHaleParker
^^ Missing ITEDO IsoView ActiveX Control 4.0. ^^
Active
Past
Past
xHeart
- RickHaleParker
Vida Media:\3PP\Products\isoview\
Active
Past
Past
- 8143 Views
Last post by jonesg
- 5352 Views
Last post by matthew1
- 4647 Views
Last post by Liliflower
- 10467 Views
Last post by nickbw898
- 2833 Views
Last post by xiami
