- Has thanked: 2203 times
- Been thanked: 4068 times
Let me know when you see flames….BlackBart wrote: 13 May 2023, 09:01 Me: “How long has it been making that noise?!”
Her: “Oh, a couple of weeks. And sometimes smoke pours out.”
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
I've had a P0496 with a CEL for a while, could be faulty purge valve.
Last inspection I deleted the code and got the car stickered ok but it made for a rough idle .
I put a light under the intake to check the hoses and found the vac hose from the top of the intake has a split along a 2 inch section, theres a check valve but its not doing anything with no vacuum to check.
Pulled the hose off and pushed a length of clear tube into it to bridge the split .
Put it all back and cleared the code, it hasn't come back again.
- jonesg
Cutting the garage concrete floor to prep for a lift, dust is too much, vac cleaner doesn't get it all.
I have a 2 cartridge respirator but its too restrictive for me to breathe, so...
I made a water feed to the diamond blade, it only produces a slurry from the dust, no cloud or water.
Water is fed by a pressurized weed sprayer.
- jonesg
Triumph C7000,
rated 7K lbs.
posts can be set as far or near as desired, no drive cables from side to side.
120v.
8 foot posts.
6 foot rise if ceiling is high enough.
$3300 delivered. Neighbor said he can unload it with his tractor.
rated 7K lbs.
120v.
8 foot posts.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Where /what did you disconnect to drain?P80GLT wrote: 15 May 2023, 12:43 Did a power steering fluid flush today. Wheels in the air, engine off and turn the steering wheel from lock to lock. 2 liters later ..
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
Raise both front wheels off the ground, I vacuum extracted the old oil from the reservoir (it is possible to pour out into a container), removed the small return pipe at the bottom (see image) and plug the return outlet port, connect extension tube to return pipe and place in a container. Fill reservoir with clean fluid and turn steering wheel from lock to lock. Check reservoir level and don't allow to run empty. Once clean fluid is coming through put return pipe back onto reservoir and tighten clamps check level, start engine and do lock to lock a few times to get any air out the system. Wheels on the ground and check the reservoir level and that's it finished.
This was the method I used...
