Has thanked: 2210 times
Been thanked: 1852 times
:lol: :lol: :lol:
Has thanked: 1611 times
Been thanked: 4073 times
BlackBart wrote: 13 May 2023, 09:01 Me: “How long has it been making that noise?!”
Her: “Oh, a couple of weeks. And sometimes smoke pours out.”
Let me know when you see flames….
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Did a power steering fluid flush today. Wheels in the air, engine off and turn the steering wheel from lock to lock. 2 litres later and it's all clean again
ps fluid.jpg (161.25 KiB) Viewed 580 times
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I've had a P0496 with a CEL for a while, could be faulty purge valve.
Last inspection I deleted the code and got the car stickered ok but it made for a rough idle .
I put a light under the intake to check the hoses and found the vac hose from the top of the intake has a split along a 2 inch section, theres a check valve but its not doing anything with no vacuum to check.
Pulled the hose off and pushed a length of clear tube into it to bridge the split .
Put it all back and cleared the code, it hasn't come back again.
jonesg
Post by jonesg »
Cutting the garage concrete floor to prep for a lift, dust is too much, vac cleaner doesn't get it all.
I have a 2 cartridge respirator but its too restrictive for me to breathe, so...
I made a water feed to the diamond blade, it only produces a slurry from the dust, no cloud or water.
Water is fed by a pressurized weed sprayer.
jonesg
Post by jonesg »
Just tried my new diamond wet saw, works as planned, leaves a nice slurry but no dust whatsoever. Its a win.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
So, what lift you decided to go with, jonesg?
jonesg
Post by jonesg »
Triumph C7000,
rated 7K lbs.
posts can be set as far or near as desired, no drive cables from side to side.
120v.
8 foot posts.
6 foot rise if ceiling is high enough.
$3300 delivered. Neighbor said he can unload it with his tractor.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
P80GLT wrote: 15 May 2023, 12:43 Did a power steering fluid flush today. Wheels in the air, engine off and turn the steering wheel from lock to lock. 2 liters later ..
Where /what did you disconnect to drain?
P80GLT
Post by P80GLT »
BlackBart wrote: 16 May 2023, 21:49Where /what did you disconnect to drain?
Raise both front wheels off the ground, I vacuum extracted the old oil from the reservoir (it is possible to pour out into a container), removed the small return pipe at the bottom (see image) and plug the return outlet port, connect extension tube to return pipe and place in a container. Fill reservoir with clean fluid and turn steering wheel from lock to lock. Check reservoir level and don't allow to run empty. Once clean fluid is coming through put return pipe back onto reservoir and tighten clamps check level, start engine and do lock to lock a few times to get any air out the system. Wheels on the ground and check the reservoir level and that's it finished.
This was the method I used...
2010 XC90 SE...SOLD
2005 V70 2.5T SE
