Vida CEM swapping
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
dikidera wrote: 08 Mar 2023, 06:44 Which would be the immobilizer key, yes? So I need to dump my CEM, the EEPROM? Copy that key to the ECU? I probably generalized the steps, but I am not sure what the steps are.
let me guess is it saying somthing along the lines of IMMOBILISER TRY START AGAIN or are you looking to find out how the process is performed ?
if so you probably best reverse engineering the old software which is floating around the internet which codecard.eu supplied some years ago
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Actually no, I have not powered on the ECU yet, but I imagine it needs to be re-programmed later on.
coormis
Year and Model: 2014
Has thanked: 2 times
Post by coormis »
vtl wrote: 24 Jan 2023, 08:09
coormis wrote: 24 Jan 2023, 08:03 hello, i try crack volvo xc90 2014 cem pin, but pin not cracked. hardware: teensy4, SN65HVD230, lm2596 dc-dc. attach log.log 01.24 not cracked.txt
can anybody help?
Thanks
Mind sharing pictures of your hardware?
coormis
Post by coormis »
can anybody help?
Thanks
oscilloscope
coormis wrote: 10 Mar 2023, 05:56
can anybody help?
Thanks
What cem unit do you have ?
coormis
Post by coormis »
31394158
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
coormis wrote: 10 Mar 2023, 05:56 photo
Did you solder CAN bus to termination resistor jumper?
coormis
Post by coormis »
vtl wrote: 10 Mar 2023, 07:10
Are you talking about the 120 ohm resistor on the SN65HVD230?
vtl
Post by vtl »
coormis wrote: 10 Mar 2023, 08:48 Are you talking about the 120 ohm resistor on the SN65HVD230?
This 2-pin yellow jumper on your CAN shield that you've soldered to OBD-II connector - what is it for? IIRC in my shield it connects 120 Ohm resistor (terminates the CAN bus). I can't check my hw right now.
vtl
Post by vtl »
By the way, the latency numbers in your log are totally off, they make no sense. That's why I suspected the hw implementation.
