Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Five posts above ThreeBear included a picture of his PCV job.
1) How many miles were on the engine before you did the PCV?
2) Gotta LOVE that there's a claw hammer n the picture.
ThreeBear
Year and Model: 2004 S60
Has thanked: 2 times
Post by ThreeBear »
Georgeandkira.
1) 2004 S60 2.4NA with 168,000. I bought the car with 80,000 and I do not believe it had been done. I didn't have any blow by or oil leaks but I did fail the glove test.
Failed Test
Failed Test
When I removed the oil trap I was surprised to see no real blockage at all, I was nervous that the replacement PCV wouldn't solve my positive crankcase issue but it did!
Passed Test
Passed Test
port into oil trap
port into oil trap
port into oil trap
port into oil trap
I am assuming something inside the oil trap was clogged up.
2) Tried to use the hammer to tap the 10mm onto the 'almost impossible to access' intake bolt. Mixed results.
2004 Volvo S60 2.4L NA 5-Speed Manual (~187,000miles)
Has thanked: 1610 times
Been thanked: 4068 times
A 1/4 inch drive ratchet, extension, and wobble will work on this.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Trolling my own discussion from a few weeks ago:
Somebody at Volvo appears to likey those VAG style bag hooks too.
Were these available in the -2018 S90 or might it be really true that VCC people keep an eye on the little things we do?
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Just posted in the other thread, but fitted some 19 inch Monaco Mirabeau wheels on my S80 Wasa Limited Edition
ImageVolvo S80 2.4T 19" Monaco Mirabeau wheels by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Technically I started yesterday but just came home:
Drove it 2 000 km. Italy to Sweden. Took about 27 hours with a three hour nap, two ferries and a few leg stretching and feeding pauses.
Car looks terrible now. The 5 000 km of brake dust from the last three weeks will take some scrubbing.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
ThreeBear wrote: 21 Jun 2018, 07:49 Georgeandkira.
Mine was the same, not clogged but the box had failed anyway (same non turbo engine)
Too late now, but these should be replaced as early as 80k miles imo, because that's about when the box gets brittle and fails internally
Rattnalle
Post by Rattnalle »
Replaced one pair of sliding pins in the rear. One came out like this. The rubber not even sitting in the hole in the caliper anymore.. :-P
ndphotonl
Post by ndphotonl »
Serviced the injectors with new rubbers, retaining ring and new filter baskets
ImageVolvo S80 2.4T Denso Injector Service by Andy Ramdin, on Flickr
As you can see, it's needed
Left: serviced. Right: non-serviced
Filter basket extractor tool
And the service kit itself, link: https://www.aliexpress.com/item/Free-sh ... 58425.html
FlickR images
Rattnalle
Post by Rattnalle »
Yay for me. This was during the weekend though. Sharp piece of gravel had punched right through the middle of the tread. Had to have it replaced with a decent used one which was cheap. Probably have to replace all four by spring anyway.
