Vida CEM swapping
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
dikidera wrote: 11 Mar 2023, 16:12 You are taking the hard approach to learning programming, I've been there waaay way back in 2007 and then later on in 2011 with C then with Java(Android flavor).
I also very long ago, wrote an Android program...on my phone when I had no access to a PC. https://bitcointalk.org/index.php?topic=101612.0 it was one of my more ambitious projects at the time but with enough patience the code will, one way or another, start making sense.
My most recent ambitious project was writing my own control flow graph generator in Java(in order to re-learn java as I had not used it for over 8 years!), it worked semi-ok. But semi-ok because I tested it on obfuscated code.
Point is, trial&error on some things. It's not efficient, but everyone has a way of learning things.
certainly do , that is why i' using chatgpt i know its not prefect , and i know the code isn't going to work , but i save ones that almost do and then i edit it where i think its going to work , and i have got really close but the code on here doesn't really work on python. it doesn't understand what the ^ (i // 7) is ment to mean , if i remove it entirely from the code and use a XOR cipher and then implement a crypto key array , of 0x3d, 0x55, 0x7f, 0x9d, 0xa5, 0xbb, 0xc3, 0xdf, 0xe it gets super close , but still not dice! , I'm going to pack it in for tonight. its already close 1pm here
coormis
Year and Model: 2014
Has thanked: 2 times
Post by coormis »
vtl wrote: 10 Mar 2023, 08:53
coormis wrote: 10 Mar 2023, 08:48 Are you talking about the 120 ohm resistor on the SN65HVD230?
By the way, the latency numbers in your log are totally off, they make no sense. That's why I suspected the hw implementation.
I cheked today my shield. its no jumper, its connected directly to vp230 6,7 pin. 120 omh resistor i removed from shield. maybe china chips is broken.
oscilloscope
coormis wrote: 12 Mar 2023, 08:24
I made mine with similar parts, I have had mixed success , as I try it on most cems I get in I think why not "have ago and see if it works "
I have the alternative CAN transceivers rick suggested to use in the github repo ? & the pcbway boards but haven't actually put them together as of yet. Have you looked up the alternative board ?
coormis
Post by coormis »
oscilloscope wrote: 12 Mar 2023, 10:54
i try search in my country alternative shields. and if its wonts work, i try pcbway board.
oscilloscope
I have been attempting too use the XOR decrypt on some cem eeprom files, so far with little success. It either doesn't perform the task , or preforms it completely incorrectly.
rkam
Year and Model: 14473_96090_XC7007
Has thanked: 5 times
Been thanked: 25 times
Post by rkam »
Your key should be 61 (0x3d) bytes long.
out[0] = ( data[0] xor key[0] ) xor 0
out[1] = ( data[1] xor key[1] ) xor 0
out[2] = ( data[2] xor key[2] ) xor 0
out[3] = ( data[3] xor key[3] ) xor 0
out[4] = ( data[4] xor key[4] ) xor 0
out[5] = ( data[5] xor key[5] ) xor 0
out[6] = ( data[6] xor key[6] ) xor 0
out[7] = ( data[7] xor key[7] ) xor 1
out[13] = ( data[13] xor key[13] ) xor 1
out[14] = ( data[14] xor key[14] ) xor 2
out[60] = ( data[60] xor key[60] ) xor 8
out[61] = ( data[61] xor key[0] ) xor 8
out[62] = ( data[62] xor key[1] ) xor 8
out[63] = ( data[63] xor key[2] ) xor 9
out[1791] = ( data[1791] xor key[22] ) xor 255
out[1792] = ( data[1792] xor key[23] ) xor 0
Key number starts from 0 every 61 bytes
Xor value from byte number starts from 0 after 1792 bytes (255 used 7 times)
oscilloscope
rkam wrote: 18 Mar 2023, 13:39 Your key should be 61 (0x3d) bytes long.
Thanks I will give that a try. And report back
eastcoasttuningltd
Year and Model: 2007 xc90
Has thanked: 1 time
Post by eastcoasttuningltd »
Looking for a place to order CY1076 I got the rest of the parts trying to build the cracker
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
eastcoasttuningltd wrote: 19 Mar 2023, 12:47 Looking for a place to order CY1076 I got the rest of the parts trying to build the cracker
You don't need level shifters to build a cracker.
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
vtl wrote: 19 Mar 2023, 13:38 You don't need level shifters to build a cracker.
I have done the CAN level at 5V ... no damage.
If you want to level shift. Use a CAN Transceiver with level shift built in.
Active
Past
