It works on his car. Also MCP2515 Arduino library is that simple. CAN.begin() == CAN_OK and you're OK.dikidera wrote: 28 Apr 2023, 04:12 Perhaps the bit timing code is wrong in your Arduino code? There are quite a lot of configuration options for the CAN bus. Bit sampling, synchronization etc.
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
stevedi
- Year and Model: 2006 V70R
- Been thanked: 3 times
This is exactly the hat I use for all of my projects, it works really well but I couldn't for the life of me get it to crack the CEM pin by connecting it to the teensy via SPI (using old code meant for a shield). I ended up soldering wires from the teensy directly to the transeivers on the hat, and it worked perfectly first try using the new code.dikidera wrote: 28 Apr 2023, 04:12 I used this CAN hat for RPI https://www.waveshare.com/2-ch-can-hat.htm and it's better in almost every single way, in that it's wired internally to the correct pins, so it's plug n play and has no messy wires.
jamezcab
- Year and Model: 2004 xc90
- Has thanked: 1 time
so here i have data read with arduino. at first i tried read all and opened in cem software but i think data is not complete lots of “ff” and some small data
so then i tried read security and have more data but dont know where to obtain pin?
why i cannot get complete read i dont know but i did remake connections a few times
volvo james .bin.txt- (41.27 KiB) Downloaded 83 times
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Memory which is not programmed is occupied by 0xFF bytes. This is normal. It's only when you do 2-3 reads and all of them have differences is when you should be concerned.
jamezcab
please take a look at attacheddikidera wrote: 28 Apr 2023, 14:52 Memory which is not programmed is occupied by 0xFF bytes. This is normal. It's only when you do 2-3 reads and all of them have differences is when you should be concerned.
T5Luke
- Year and Model: S60 T5 2001
- Has thanked: 11 times
- Been thanked: 130 times
Think you have some connection error, data doesn't look right to me
if you read from 0x0000 you should get something like this:
Code: Select all
00000000 00 FF D2 00 00 00 08 00 00 00 04 24 00 00 04 24 .ÿÒ........$...$
00000010 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
00000020 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
00000030 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
00000040 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
00000050 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
00000060 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
00000070 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
00000080 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
00000090 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
jamezcab
T5Luke wrote: 28 Apr 2023, 15:31 Think you have some connection error, data doesn't look right to me
Code: Select all
00000000 00 FF D2 00 00 00 08 00 00 00 04 24 00 00 04 24 .ÿÒ........$...$ 00000010 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$ 00000020 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$ 00000030 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$ 00000040 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$ 00000050 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$ 00000060 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$ 00000070 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$ 00000080 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$ 00000090 00 00 04 24 00 00 04 24 00 00 04 24 00 00 04 24 ...$...$...$...$
thank you it appears that you must use power supply for arduino when using the 5 volt output to supply the cem
jamezcab
is this file good? still cant make work with cemtool but i cannot make into .bin
volvo labrat cem.txt- (1.28 MiB) Downloaded 89 times
- 9693 Views
Last post by RickHaleParker
- 9908 Views
- 27 Replies
- 30660 Views
Last post by cn90
- 11591 Views
Last post by jonesg
- 6668 Views
