1998 v70 GLT
- Been thanked: 4069 times
That’s the UFO, which Volvo calls the supplemental air system. It injects air into your exhaust on cold start for emissions reduction. A vacuum leak can make cold running hard, yes.
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
Ok so I replaced that little bit of hose.
Looking at other things
I found this connection (I think it's the IAC idle air control valve) that has a bad connection
Cleaning it with contact cleaner now.
Here are some pics.
Looking for other things, then may reassemble and test.
After I clean the distributor and the rotor. And yes I do have the little plastic thing that keeps the rotor and inside the distributor dry...
Hopefully one day...I can get the piping for the straight intercooler pipe over the cylinder head modification...and then rip in and (rip kit I think it's called) rip into everything and replace with silicon hoses
Ok, lemme keep working and see what happens.
Big Al
Here are some pics.
Big Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
surfbug1
Well it seems to run better, but still skips a beat when warmed up.
And if I smash the throttle it falls on its face.
I will see how it is going to work tomorrow.
Fuel. Spark. Vaccuum. Hmmmm dunno which one to chase.
Maybe I will make a short video of the behavior when it is warmed up. After work tomorrow.
Thanks all
Frustrating, I am gonna start to throw parts at it, and I don't have the money to do that right now.
So I have to be selective
Al
Thanks all
Al
Ping me!
Ping me!
shadetree_v70
- Year and Model: 1998 V70 GLT
Some free things to do (maybe you've already done these)
- Inspect every inch of vacuum lines, also listening for sounds of leakage.
- As mentioned previously, clean the cap and rotor contacts with emory cloth or similar, or scrape carefully down to clean metal.
- See if you can locate broken wiring to your OBD port. Seeing the SES light but not knowing the code will only slow this process down. (Maybe this should be at the top of the list)
- Clean the throttle body
- make sure air filter isn't clogged
- every hour, take a 10 minute break and regroup. Do something totally different; sometimes a quick reset helps get out of "ruts of thought"
Good luck!
Good luck!
surfbug1
Shade tree....thanks!
Will address this on Sunday..since I work the next few days.
Seems to be doing ok limping back and forth to work.
But still having the issue.
Let's see
Air filter-- checked and ok
Throttle body clean-. I think I did that somewhat, but will find a thread on here on HOW to do it, and actually do it!
Rotor and cap clean- yes, will be borrowing a Dremel tool , and gently scraping the contacts clean
Checking all vac lines. --- sometimes following allllll the lines and reading the line schematics are a PITA
Any lines to check first? (I know, all of them)
Wiring to OBD port-- any one have a schematics on this? Thanks!
Let's see
Ping me!
Ping me!
- 17 Replies
- 3219 Views
Last post by skloon
- 11 Replies
- 3899 Views
Last post by dwhite66
- 976 Views
Last post by shadetree_v70
- 443 Views
Last post by Ben850
- 764 Views
Last post by misha
