Best Place To Break Through The Engine Compartment Firewall
Has thanked: 1611 times
Been thanked: 4072 times
There’s plenty of room to drop a wire. Chafe relief it with heavy tape or hose though.
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
abscate wrote: 21 Feb 2023, 18:00 There’s plenty of room to drop a wire. Chafe relief it with heavy tape or hose though.
Hi,
Where, other than the tube?
Plenty of room Around the relay bracket under the main fuse box. Be sure you zip tie off the wire so it doesn’t chafe against moving parts like the pedal cluster or steering gear.
I dropped a 12 V accessory plug on Evita using this method
MrAl
Post by MrAl »
abscate wrote: 22 Feb 2023, 03:07 Plenty of room Around the relay bracket under the main fuse box. Be sure you zip tie off the wire so it doesn’t chafe against moving parts like the pedal cluster or steering gear.
Hi,
Can you show me where that is on this photo?
Note that the hole with the missing relay does not show light when a light is shone up from below inside the cabin.
Thanks.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
This isn't hard. I wish I wasn't still having issues with downloading pictures, so I could post one (1000 words etc ).
I'm using a fuse tap for one of my accessories, and I just drilled a small ( 1/8" ) hole down through the thin plastic base that the fuse block is mounted to. In the above pic, the space between the weather seal and the block, left side just before the angle starts. I notched the rubber piece that is just out of sight in the pic ( lower left ) for the wire to pass through the block to the fuse.
1999 V70 GLT
MrAl
Post by MrAl »
Sveedy wrote: 22 Feb 2023, 07:17 This isn't hard. I wish I wasn't still having issues with downloading pictures, so I could post one (1000 words etc ).
Hi,
I see torx head screws can you remove that whole fuse block up a little to get under it to pass a wire?
Sveedy
Post by Sveedy »
Maybe, but that plastic is brittle, so I would keep it simple, and not remove any more than necessary. Much like an old house, one thing can quickly lead to another.
Look at it this way; there is only 1/16" of plastic keeping you from victory. Drill the little hole, and be done with it. And in the future if you no longer needed it, you can put a dab of silicone over it and no one will tell.
1999 V70 GLT
MrAl
Post by MrAl »
Sounds interesting.
The hole i need would have to be around 3/8 inch diameter (0.375 inch diameter).
Sveedy
Post by Sveedy »
In that case, I'd go back to the factory tube. I just had to run one power supply wire from the fuse block. Picked up the ground once inside the car.
1999 V70 GLT
MrAl
Post by MrAl »
Sveedy wrote: 23 Feb 2023, 15:15 In that case, I'd go back to the factory tube. I just had to run one power supply wire from the fuse block. Picked up the ground once inside the car.
Yeah i think im stuck with that method.
Just hard getting access to the end in the car cabin area.
