Hello there,
Is there a best place to push a wire through the firewall?
The size is the same as regular zip cord which is the cord that is used on most regular house lamps. It is two conductor, not very wide, about 1/4 inch wide, and about 1/8 inch thick as there are two wires next to each other.
I am going to run a wire from the battery terminals to inside the passenger compartment and that means it has to run through the firewall. I did this in my old Hyundai but that was easy as there was a big round grommet so all i had to do was push the wire through. With this Volvo 1998 v70 i am not so sure where the best place would be where i would not have to drill a new hole.
Thanks.
P.S . This should be the last problem i have to solve in order to run a wire from the battery to the inside for various power and monitoring purposes.
Best place to push wire through firewall
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- kranz
- Year and Model: '98 V70 NA stick
- Been thanked: 8 times
IIRC VOLVO installed an accessory connector that offers fused switched/nonswitched power in the passenger compartment. It is located under the dash on the driver's (LHD) side. Color is yellow. This has been discussed previously in the forum and if you search the forum you will find it complete with photos. It will save you a lot of work.
Les is more.
- Has thanked: 316 times
- Been thanked: 531 times
I remember hearing about that, but I haven't seen it. Then again, I haven't gone looking for it. BEJinFbk posted something about it I remember.kranz wrote: 14 Sep 2017, 13:52 IIRC Volvo installed an accessory connector that offers fused switched/nonswitched power in the passenger compartment. It is located under the dash on the driver's (LHD) side. Color is yellow. This has been discussed previously in the forum and if you search the forum you will find it complete with photos. It will save you a lot of work.
If you want to go straight to the battery, there is a grommet below the main fuse box that passes through just above the fuse panel above the brake pedal. Hard to find from the inside sometimes, but it's up there. Just cut a "tentacle" off and run the wire right through.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
If you look up my boost gauge install I show pictures of the gromet, it is excellent for passing wires.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- Has thanked: 311 times
- Been thanked: 817 times
OP knows all about the accessory connector with its various forms of switched and constant power viewtopic.php?t=69527.
- MrAl
Hi there,kranz wrote: 14 Sep 2017, 13:52 IIRC Volvo installed an accessory connector that offers fused switched/nonswitched power in the passenger compartment. It is located under the dash on the driver's (LHD) side. Color is yellow. This has been discussed previously in the forum and if you search the forum you will find it complete with photos. It will save you a lot of work.
Yes i had asked about that previously on here, and i did find it, but then i'd have to look again because it's been a while since i was looking for that (some years back now).
However, this time i wanted to install my own complete system that would be completely independent of any other elecrical item on the car, hence my desire to push my own wire through the firewall. This is for different reasons such as wire gauge and fusing control, as well as not bothering anything else on the car. I also want a ground wire so i get both terminals right from the battery rather though the chassis of the car.
Thanks for the suggestion.
- MrAl
Hi,
Thanks again Robert, nice video too. I had forgotten all about the hood release cable too and that may be the simplest for me. I want to run both the positive and negative terminals to the inside of the car.
That's the funniest looking grommet i've ever seen to date, and i've seen a lot of them in my time
- 1601 Views
Last post by rspi
- 47 Replies
- 4531 Views
Last post by MrAl
- 23 Replies
- 7996 Views
Last post by BEJinFbk
- 421 Views
Last post by RickHaleParker
- 16 Replies
- 7146 Views
Last post by tjalle01
