Well, it is what it is they say. Mine has been running ok and has been sitting for the 12 years I've owned the car and a few before that too. I think it was installed around 2010.
Anyway if you want it let me know and happy to work out shipping but will need a Zip Code to estimate. PM me if you want it but no problem if you want to pass.
Question for the ETM and ME7 experts - RESOLVED Topic is solved
- Has thanked: 2200 times
- Twarr12000
- Year and Model: 1999 S70 GLT
- Has thanked: 35 times
- Been thanked: 19 times
PM sent. Thanks!
- Twarr12000
I replaced the ETM with a third unit and the problem seems to be resolved. I’m still getting the older Xemodex unit from scott850, because frankly I don’t trust the OEM ones.
To recap for those that don’t want to read through the entire thread; car ran good for a few minutes on startup but shortly after going into closed loop the ‘Actual Throttle Position’ (as called on my cheap generic scanner) would freeze. On restart it showed 0 degrees. After sitting overnight it would go through the same scenario again. I replaced the throttle module with 2 different salvage units, the 2nd one cleared up the issue. Disconnected the battery for 1/2 hour to clear adaptations and the engine runs fine.
Now on to the next set of issues with this Hellmobile
- 904 Views
- 705 Views
Last post by cn90
- 2928 Views
- 2349 Views
Last post by Bob 88
- 784 Views
Last post by clifford06
