What was suggested for testing the MAF is to unplug the wiring connector to the MAF and then see if the engine runs better after with it disconnected. It is only a test, not recommended for running the car on the road. The ECU reads the information from the MAF to make adjustments to the engine. When you disconnect it it goes to data programmed into the ECU. If the car runs the same with the MAF connected or disconnected it is not the MAF. It is worth cleaning the MAF with specific MAF cleaner and see if that helps before buying a new or used replacement. Bosch used to be the go to for this but I believe they are no longer made. Volvo still had a stock but at a stupid price.
Urgent Help Finding Oil Leak Topic is solved
- Has thanked: 2199 times
BeerDeer
- Year and Model: 1996 and Volvo 850
- Has thanked: 2 times
- Been thanked: 3 times
I discovered that the hoses and parts I purchased are not compatible with my vehicle. It appears that most retailers are only selling the hidden Turbo PCV model, whereas I own a non-turbocharged and automatic Volvo 850.
Additionally, I am unsure whether my car is equipped with an EGR system, as its presence seems to be dependent on which PCV system to order. I would greatly appreciate any assistance in finding the right PCV for my Volvo 850
These cars don’t use EGR. Some models have SAS , supplementary air system
Corrected. EGR USED UP TO 1996 on some models. Look at vacuum sticker under hood for quick chevk
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
SAS is an air pump and some hoses, mounted towards the firewall, if I remember correctly. Ask Google, there should be photos out there.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I'm pretty sure that the '94 I was pulling parts from in the junkyard had an EGR.
1999 V70 GLT
1999 V70 GLT
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'91-'95 yes....'96 & '97 no.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- DennisCA
- Year and Model: 1996 850
- Has thanked: 6 times
- Been thanked: 67 times
You don't have EGR, but you very likely have an SAS, the air pump is somewhere below the battery. There should be a hose from the air intake that connects to the air pump.
BeerDeer
I encountered another issue today. When I started the car, it was difficult to start. The cause could be the PCV valve, the relay pump, or any other potential issue. I proceeded to drive the car. When I put the car in reverse, it worked fine. However, when I shifted into drive (D), the car stalled. I tried shifting back into reverse, and it worked again. When I shifted into drive (D) once more, the car stalled again. Interestingly, when I used the winter mode, the car was able to drive without any issues. I am wondering if there is a problem with the transmission. I will try flushing the transmission fluid to see if that resolves the issue.
- 2602 Views
Last post by gordo850turbo
- 369 Views
Last post by RoyAPhilpot
- 17 Replies
- 4203 Views
Last post by E Showell
- 1499 Views
Last post by bmdubya1198
- 1300 Views
Last post by Ozark Lee
