I hold no objection to where you live, but you don't experience a proper winter there and thus it was a reasonable assumption to say that you haven't experienced the need for synthetic, this is not Ad Hominen.bright wrote:Yes, I have lived in the Arctic as well. It is very cold. Your face stings when you step outside and taking a shower feels like your skin is distinctively uncomfortable. And Volvo's are designed in Sweden, which lies primarily above the Arctic circle. Where I currently live isn't important in this argument and really is a form of ad hominem attack.
http://en.wikipedia.org/wiki/Ad_hominem
Your machines do not start with bare metal to metal contact. There is always a bit of oil hanging around on the surface.
Oil filters have a valve that prevents reverse flow. This leaves plenty of oil ready to jump out of the oil galleys and lube away. If anything the cold would keep the oil gooey and stuck around the contact surfaces.
You should know this![]()
In regards to your pour test, we have a saying in science:
Anecdotal evidence is not evidence.
http://en.wikipedia.org/wiki/Anecdotal_evidence
That is, the experience of one does not provide proof. It takes many, many experiments to make a strong case. And even then you must prove that your idea stands up against critiques. Otherwise it is just a testimonial.
Wikipedia does have an interesting article oil:
http://en.wikipedia.org/wiki/Motor_oil
I didn't know that "W" stands for winter pour rate, not weight. It's a test in which a certain amount of oil will pour through a certain sized hole at a certain temperature with "X" amount of pressure.
And yes, there is a section on synthetics but no citation was given. That makes it a testimony of an editor.
Again, if synthetics were all that you would find them mandated for all cars. They would be required by warranty. But they aren't. It's the same way oil companies still say that you should change your oil every 3,000 miles. That's definitely no longer true. But they like it, it makes them loads of cash.
And your cars are not starting for other reasons. A car completely devoid of oil will happily jump to life and seize up in a minute or so. The "Cash for Clunkers" was a great example. When a car was traded in it had to be destroyed. This was done by draining the oil and then pouring in a thin oil full of ceramic particles (think quartz sand). It took around 2-5 minutes for each car/truck to give up its ghost.
Science gets proven based on repeatable anecdotal evidence, look around and you will see 1000's of cases attesting to the improved cold flow characteristics of synthetics. No I don't have to waste my time collecting this for you(I have done it for myself as well as tested it unlike you). If you want to discredit me by essentially saying "that's only your personal non scientific experience," then by all means go ahead. Keep in mind the truth isn't always what we think it is, an unproven concept could still be more true than a scientifically evaluated "fact." Given that you seem to know a little bit about failures in argument etc, then you may also have read Platos Analogy of the Cave, I urge you to consider it.
By the way where did you live in the Arctic Circle?
- Jesse
