I have a '97 Volvo 850 NA and have a stuck odometer.
I built the circuit almost how it was shown in the picture (without the resistor since the LED has a built in resistor) and cannot get the circuit to give me any readouts.
With the engine off and the circuit attached, the LED is on. When the key is set to the ignition or the ignition is turned off, the LED goes out. Clicking the button causes the LED to light up.
I followed the procedure to read the mileage in one of the referenced forum entries. Clicking the button 5 times does nothing other than light the LED with each press. Following this up by clicking the button in sequence 1-1-1 also does not cause it to blink according to the mileage counter.
Here are the parts I used from RadioShack followed by pictures of the circuit and the circuit attached to the OBDII connector:
Part Number 275-1547 SPST Mini Momentary Pushbutton Switch N.O contacts rated 3.0A at 125VAC, 1.5A at 250VAC
Part Number 276-0209 5mm Red LED 12VDC 20mA 1.5mcd with integrated resistor
Please let me know if I've not built the circuit correctly and how to correctly press the buttons to try to get a readout (i.e. long press, short press, etc).
Thanks,
Mike
Playing with the OBD-ii... got the mileage?
Correction to my previous post...
With the engine off and the circuit attached, the LED is on. When the key is set to the ignition or the ignition is turned on, the LED goes out. Clicking the button causes the LED to light up.
- 3330 Views
Last post by Sommerfeldt
- 550 Views
Last post by misha
- 17 Replies
- 3663 Views
Last post by ARMeyer27
- 1437 Views
Last post by precopster
- 1446 Views
Last post by JerseyT5
