DIY: 1998 V70 Axle CV Rubber Boots Tips/Tricks
This topic is in the MVS Volvo Repair Database » Do It Yourself CV Boot Repair - Volvo V70
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Hi XHeart, I just did my daughter's axle on her 850. It was a rush job. I got the boot from NAPA and it was excellent. It was as heavy as the original. The replacement boot from Advance was thinner and flimsy. Do not know NAPA mfg, but it was specific for a 850. I have the crimper for the boot clamp if you need to use it.
camjohns
Year and Model: N/A 850 97, 850R 96
Has thanked: 6 times
Post by camjohns »
Just saw the other day that my outer cv boot on passenger side ripped off from the clamp. I didn't notice it last week when i replaced my control arms, sway bar links and outer tie rod ends. Im leaving for a 7 hr trip this weekend and was wondering if it would still be ok to drive with the boot detached like that? I dont hear any noise when i turn from either side so im assuming its still good.
thoughts?
kahl
Post by kahl »
It should be fine for your trip. There is numerous cars driving around with torn boots. Is there enough boot left to reclamp for your trip? When you return pull the axle and follow the boot replacement in this thread.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I know that my daughter drove for at least 6 months with boots torn. I replaced the boots 15 months ago (on Christmas eve) and still no issues. Nice smooth and quiet.
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
GKN boots are available at Pelican parts for under 15 each. Search by PN 31256231.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
camjohns wrote:Just saw the other day that my outer cv boot on passenger side ripped off from the clamp. I didn't notice it last week when i replaced my control arms, sway bar links and outer tie rod ends. Im leaving for a 7 hr trip this weekend and was wondering if it would still be ok to drive with the boot detached like that? I dont hear any noise when i turn from either side so im assuming its still good.
thoughts?
For "emergency" or "ghetto" repair until you have time to fix it, some people say:
- Wrap the torn rubber part with a few layers of Duct Tape.
- Go from end to end so you have complete coverage.
- Avoid dirty road (country road)
- Avoid driving in the rain.
This should give enough time until you fix it.
Also, do a google search using key words "CV boot emergency repair".
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
I would patch it up and drive.
I have done interim boot repair on an 850, using a plastic garbage bag and duct tape. It lasted for a couple months until I pulled the axle. Make sure you leave enough slack for the steering to go in both directions without tearing/stressing your ghetto repair.
GKN/Lobro outer CV boots are $8 each at AutohausAZ.
camjohns
Post by camjohns »
thanks for the replies!
How would i go about re-clamping it if there is enough to clamp? zip- tie?
Its not cracked from what i can see, just pulled away from the exterior clamp, i can see the moving parts themselves. Not sure if i could duct tape that? Ill play around with it this afternoon and see what happens.
thanks!
kahl
Post by kahl »
If the boot slipped off the hub I would get another clamp. Stretch boot over the hub and make sure new clamp is in the channel of the hub when you crimp.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Here are two GKN outer boots installed, cn90 you rock!
Full story here https://www.matthewsvolvosite.com/forums/viewtopic.php?f=9&t=62033.
Are the clamps look OK, should these crimp more?
2007 XC70 front axles - outer cv joint service, reluctor rings, and boots
