What type of fuel are you using?
geokilla
Year and Model: S70, 2000
Re: What type of fuel are you using?
Post by geokilla »
Ultra 94 in our 2000 S70 SE. However lately, we've switched to regular. There's an impact in performance and fuel economy so we MIGHT switch back to Ultra 94.
2000 Volvo S70 SE; First Owner; 321km; Retired
2012 Volvo S60 T5 Level II; Gone
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
You're going to burn your exhaust valves.
geokilla
Post by geokilla »
polskamafia mjl wrote:You're going to burn your exhaust valves.
As per the pics in the previous page? How? I've known people that said they ran regular pretty much their car's entire life despite it recommending premium....
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
In the US, Regular is usually 87, Mid-grade 89, and Premium 91. Now, I don't know what regular and mid-grade is in a place that has "Ultra 94", but first off the octane is not AS important in a naturally aspirated engine. But here, people use 87 in these cars all the time, no issues. But to have the peace of mind, you can run 91. So I doubt anyone will run into burned exhaust valves in a place where premium is 94 and regular is what... 90?
What is the regular in Canada?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
geokilla
Post by geokilla »
ecbsykes wrote:In the US, Regular is usually 87, Mid-grade 89, and Premium 91. Now, I don't know what regular and mid-grade is in a place that has "Ultra 94", but first off the octane is not AS important in a naturally aspirated engine. But here, people use 87 in these cars all the time, no issues. But to have the peace of mind, you can run 91. So I doubt anyone will run into burned exhaust valves in a place where premium is 94 and regular is what... 90?
Ultra 94 is found at Sunoco and Petro Canada. I believe Texaco and has it too as I remember seeing it at one of their gas stations while in Florida.
USA octane rating and naming is the same as Canada.
FlyingVolvo
Ah ok, wasn't sure on that one! Thanks.
I run Premium 91 in mine a. because it's a turbo b. it eliminates any doubt. But yeah, millions of people will go hundreds of thousands of miles with regular in a car spec'd for premium. I think it really depends on how you drive and the upkeep of general maintenance.
2023 V60 T8 PE
polskamafia mjl
Go ahead and run regular. Report back to us on what happens.
geokilla
Post by geokilla »
polskamafia mjl wrote:Go ahead and run regular. Report back to us on what happens.
You tell me to run regular here, then mid-grade or premium in the other. Make up your mind!!! lol
We've been running regular for the past month. Like I said, the fuel economy and the performance decreased.
vegasjetta
Year and Model: 98 V70
Post by vegasjetta »
polskamafia mjl wrote:Stage 0, tire pressure, dragging brakes, AC, uphill/city driving?
So far, I am halfway through stage 0. New cap, rotor, wires. Plugs are going in today. I need to change the oil, but I doubt old oil will cause bad fuel economy, to an extent.
Not much AC use, mainly city driving. I don't think the brakes are dragging.
club Grim Water in 010
FlyingVolvo
How about O2 sensors? When were they last replaced (if ever)? As they get older they don't always produce the right signals and can semi-fail without actually displaying the CEL. Might net a few more MPG with that.
I'm about to change out my original ones at 140K, wish I had done it sooner though.
2023 V60 T8 PE
