What type of fuel are you using?
I am just curious as to what fuel most people are using in their 850's, are you using regular or premium? I think the manual for my 1995 850 says to run high octane premium fuel but for the 1 year that I have had my car I always just put regular.
- Has thanked: 2866 times
- Been thanked: 1332 times
Mid or high grade. Regular makes my 850 bog in the summer with its higher ambient air temps + thin air here in Denver.
I was running reg. for awhile when I first got my '96 850 na (oct '09)....then in Jan. I switched to prem....It seems to be quite a bit happier with it.(doing some mileage checks now) I was getting 23.5 on reg.average around town and some short trips....I'll keep you posted on what's going on with premiumnadz wrote:I am just curious as to what fuel most people are using in their 850's, are you using regular or premium? I think the manual for my 1995 850 says to run high octane premium fuel but for the 1 year that I have had my car I always just put regular.
bigdaddylee82
- Year and Model: '95 850 GLT+94 parts
Regular 87 Octane in my 95/94 850 GLT.
Everything around here has been 10% Ethanol for at least 5 years now.
You turbo guys "might" need a higher octane, but I have never had any premature detonation/valve rattle/knock with regular in my tank and I've been driving the car for almost 6 years, and my sister drove it for about 3 before I got it. Knowing her it had the cheapest she could find in the tank.
- Lee
- Lee
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
89, or 93 if I'm going on a long trip. My car hates regular.
I generally try to stick to either Shell or Hess gasoline, as I've found some of the off-market brands to be watered down, and after several experiences with my old car not liking cheap gas, I've found those stations to be the most consistent.
'98 S70 T5
2016 Chevy Cruze Premier
Super Plus unleaded here in the UK or 98-99Ron with a Water/Methanol injection so technically 103octane car loves it
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
89 minimum and then 91 or 93 during inspection week. Burned exhaust valves and better gas mileage keep me from touching that 87 garbage.
