I've got a Volvo V70 AWD XC 12/1998 Engine is a B5254T
My pre cat oxygen sensor failed . P1132 code came up . Replaced it first with a Bosch sensor from fleabay with the same part number but after a week the check engine light came up again.
Been to scrap yard last week and took a sensor from another Turbo Volvo en fitted it this morning.
The one now fitted is the not a 100% match but was the predecessor of the one needed and works fine.
What has failed on your 1992-2000 FWD or AWD Volvo?
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
I think this should reworded, some people are going to check off things that have worn out, and not failed.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
98T5 Turbo
Just changed out my control arms, spring seats and strut braces over the weekend. next will be upgrade to braided brake lines.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
OtosanOokami
- Year and Model: 850 1996
The heater Core was the only really catastrophic failure in the 850. Few other things have gone, true, but they went in more of a "slow decomposition with plenty of warning" sort of way.
Truly amazing work they did in 96.
96 850 Turbo- 146k+ 8 years of daily commute with a broken Odom gear.
03 XC70 (RIP) 2/11/13
My 98T5 is currently working on:
1. oil cooler lines
2. broken door accuator
3. broken cable/hood mechanisms
4. RH wheel hub assembly
1. oil cooler lines
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
Again, great idea but I think maybe because of the check thing (I could be wrong) -- you may have some accuracy problems. ABS module 0% ? Isn't that one of the biggest gripes?
When I first saw this I checked to the left -- (ok, I'm an idiot?)
cardiegoV70
- Year and Model: 1998 V70
Door lock actuates but doesn't lock passenger door. WTH?
madspeed50
- Year and Model: 1998 S70 T5m
rear cam seal, leaking like a mofo right now
- 1605 Views
Last post by foggydogg
- 2522 Views
Last post by RickHaleParker
- 802 Views
Last post by ddavis6900
- 2641 Views
- 2391 Views
