1999 s80 timing off
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
precopster
Year and Model: Lots
Been thanked: 128 times
Re: 1999 s80 timing off
Post by precopster »
Put up some resistance or came to a dead stop?
Are spark plugs out? Could just be compression resistance and the weight of 6 cylinders :?
az volvo
Year and Model: 1999s80
Post by az volvo »
no, the plugs and cop's are removed. dead stop. not resistance
precopster
How closely are you adhering to the Vida procedure I attached?
The only thing I can think of now is bad crank referencing and/or bad cam referencing or more bent valves.
When you pulled the head off were valves seated in their seats or were there gaps. A simple test is to fill the combustion chamber with gas/fuel and test for leaks.
az volvo
Post by az volvo »
i just received the head back froim the machine shop. i did a light test to make sure they were all seated. i will go back over the Vida procedure.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
AZ,
When you are indexing the cams, are you setting the slots horizontal such that the intake cam slot is slightly above center and the exhaust slot is slightly below center?
az volvo
Post by az volvo »
yes, it is exactly like the picture you sent me. it is a straight camlock so i may be off ever so slightly, but i am giving it another shot. the only valve going down in question is #3 on intake. but the piston is going down, so i don't think it is a problem.
az volvo
Post by az volvo »
it must be in the VVT. but if the cams line up and the vvt is clockwise as far as possible and mark is right then it should be in relative timing, correct?
