98 S70 glt Engine issues major!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Duake wrote:...New Iridium spark plugs put in about 3 months ago.
Take them out as soon as you can.These cars doesn't like them.They will not work properly in these cars.It is a miracle that they are working properly for now,but it doesn't mean it will last.
Put in OEM Volvo spark plugs (the pack of five) or just the cheap copper Bosch or NGK properly gapped.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Duake
Year and Model: S70, 1998
Post by Duake »
Why don't Volvos like the Iridium plugs? Something wrong with them?
Has thanked: 1610 times
Been thanked: 4065 times
On iridium plugs :
Turbos don't like them, naturally aspirated it seems they are ok from experiences on this board
Duake
Post by Duake »
After fixing the problem last week, on Tuesday, the pump got more "sediment" or whatever sucked into it. I took it out to clean it off and to see if I couldn't get the remnants out of the bottom. Well, I took a light and shown it down around the tank and found some scary results:
I don't know what this junk is, but apparently it has crystallized into a rock form and probably around 3" long. There is another on the right side and you can barely make it out on the right in the tank. Also, you can see the little particles on the bottom where the pump goes and a larger chunk on the left in the chamber.
ANY ideas on what this stuff could be? I plan on getting the little metal wire "hands" where you push on the plunger and you can grab stuff with them. I'll see if I can't get these "rocks" out and take a picture of them.I'll use a siphon to get the small junk out as well.
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
I'm not familiar with the gas tank on a GLT but if doable, I'd pull it out and have it professionally flushed clean. Something's really not right there. A long shot, but do you always get gas at the same place? I'm wondering if maybe you got a load from the bottom of their tank. For a time, try a new station, one that gets a lot of business. Be sure to use at least mid grade and fill the tank.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Pull some and put in a Baggie and send to me. I have access to a complete lab including most every analytical instrument known to humankind. PM me for address
QuirkySwede
Year and Model: 1998 S70 GLT
Been thanked: 12 times
Post by QuirkySwede »
+1 on FLUSH THAT TANK. :shock: You may be looking at another fuel pump and fuel filter too, cheap compared to what is "downstream." Siphon the tank as empty as possible. You'll want to put the rear on jackstands and have a board distributing the weight of a jack snugged under the plastic tank before removing the three bolts for two straps. Don't cross-thread them when reinstalling. The tank is HDPE (#2) if I remember correctly, but I doubt you want to go down that road. :twisted:
No. Avoid coppers trying to save a buck or two as they won't last as long, Bosch won't warranty them and they cost more in the long run (replacements per 100k, labor, plug wire stress at change). The OEM plugs DO have iridium (Bosch FR7DPP+, an "OE Specialty" plug, not an off-the-shelf type), albeit a platinum-iridium alloy. Any parts store that doesn't stock them can order them in (see the link). Run what you have 'til bad* then switch.
"Platinum" ones are a low-iridium (and platinum) alloy.
"Iridium" ones are a higher-iridium (and platinum) alloy.
* The non-finewire ones (just a dot on the ceramic center electrode face) can foul easier. Check.
"Copper" are actually a CuYt alloy.
The "PP" is for "Double Platinum" refers to both the ground and center electrodes being "platinum."
abscate wrote:Sugar would actually nicely dissolve in the fuel...
Nope.
Sugar = water soluble.
Gasoline = not water soluble.
Hence, just like water and oil... :wink:
Water (H2O) = very polar molecule (10.2).
Gasoline (C8H18) = negligible polarity (0.1).
The polarity is what lets water pull apart sucrose (sugar), whereas gasoline is going to have a hard time overcoming sugar's own bonds.
If you have water in the gas, it can mix with that. There might also be ethanols, alcohols (Heet, Iso-Heet), detergents, and other stuff in there, but the "sugar in gas" stuff is a myth.
Duake
Post by Duake »
abscate wrote:Pull some and put in a Baggie and send to me. I have access to a complete lab including most every analytical instrument known to humankind. PM me for address
I think I might be able to open it up again this weekend so I can get that junk out. I don't know if I'll be able to maneuver it around the plastic circular levels, but I'll try.
Duake
Post by Duake »
rmmagow wrote:I'm not familiar with the gas tank on a GLT but if doable, I'd pull it out and have it professionally flushed clean. Something's really not right there. A long shot, but do you always get gas at the same place? I'm wondering if maybe you got a load from the bottom of their tank. For a time, try a new station, one that gets a lot of business. Be sure to use at least mid grade and fill the tank.
I actually get gas from multiple places, so I don't think that's the problem. I always use 89 octane when I fill up. I've used Octane Boost a couple times, but I don't know if that really does anything.
Duake
Post by Duake »
Okay, I finally got all that crap out of my gas tank! I actually managed to shove my whole hand in there and just pull it all out. I will have to take pictures and post them a little later.
abscate: I will have to send you some of this just to see what it is!
