2005 V70NAM56 CATHERINE 496197 Manual 5 into code A981 Saurus 15inch wheels
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
Has thanked: 1609 times
Been thanked: 4063 times
2023 placeholder maintenance record
143500 miles
Upcoming 150k service: coolant change, spark plug change, serp belt, new battery, air filter
Bookmark to total tech for key programming
viewtopic.php?t=101291&start=10
Backup lights are out, FEBI switch from FCP. Circuit diagram here
viewtopic.php?p=619310#p619310
Replaced switch. 22 mm socket ftom up top one connector. Passed NYSI feb23 145xxx
Rear wiper replaced July 1 FCP https://www.fcpeuro.com/orders/R481652799
30 Sep 149353
Oil and filter change
Coolant change Volvo coolant FCP
19 October
Replaced air filter, Volvo
13 November
Installed rebuilt BCM , fuse 19 blue and unit ran hot. Bcm0700
Pulled both 14 and 19 fuses , will send back to Xemodex
2026
4 SEP 159600
Power System fault on dash plus red battery icon
Measured voltage at POS point 11.4 Volts at idle
CEM codes for ALT fault to follow
1 Feb. rear tires 2/32 and cupping, replaced with Shagg tires, approx 50k Miles on the CS5 195/65-15 tires!
New NAPA BATTERY dated 8/23 , replaced dec 7 2023 with the 7548 part
Link to trunk and interior dimensions thread
viewtopic.php?t=85868
Passed NYSI at Munch
Left rear tire slow leak of Shagg tire. May 10
Replaced brake lights 1157 , behind rear speakers in D pillar
10 years on timing belt, 56k miles ( changed all components at 100k)
Left reverse light out, bulb is
Munch NYSI 2025-03-02 156k
Replaced right front wheel bearing
Left reverse light bulb
2025-05-28 oil change , filter change 157500
200 miles at 70 mph 33.4 mpg
Winter stuff
Need to return ABS module to Xmodex for warranty
Diagnosis from Xmodex. ABS module failed not under warranty. $1300 for repair and may need new hydraulic lock
Dissastisfied customer
Came to fair and reasonable terms. Received a rebuilt module, body and motor and installed during evening.
viewtopic.php?t=107869
Has thanked: 2196 times
Been thanked: 1850 times
Did you have the repair done under your name? If so, why was it not covered?
I was not happy when my V70R Xemodex rebuilt ABS module started to play up to find like vehicle batteries, only the original purchaser was covered, even though the item was only 3 years old and had a 'lifetime; warranty.
Naturally I went to Matty and got one of his units.
scot850 wrote: 25 Jan 2026, 23:02 Did you have the repair done under your name? If so, why was it not covered?
Negotiating settlement with Xemodex. Here’s the ugly on the unit. Power Q blown up.
Update., we came to a good agreement. I decided to replace the whole block for both time and reliability reasons
March 11 2026 158xxx back on the road with brakes and speedo
Dropped it a Volvo for new windshield and airbag recall
Cinco de Mayo - NYSI MUnch 154800, replaced windshield at Volvo
(Juliette windsheild at Safelight - NYSI)
Towed a p80 130 miles on dolly. 22 mpg loaded 26 mpg unloaded
Rear wiper inop
Stop lamp check warning on
Replaced left brake bulb 1156 21W
Replaced left rear stop lamp bulb 1156 21w
2026-06-01. 156xxx
Replacing rear rotors pads and parking brake shoes,
viewtopic.php?t=108200
LASt history
{Ny state inspection 128600
Had to replace rear rotors for rust and also clean fuse 1 in REM to fix inop reversing lights
New rearvtotors and pads, flushed 750cc brake fluid
Ordered on FCP Shipments
Order #:
R525030404}
2026
4 SEP 156600
Alternator out
viewtopic.php?t=108539
