Does the oil trap even go bad?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The main reason I say that is, my dipstick had NO smoke at all. Pulled the box and the system was is very bad shape. Lower port clogged 80%, upper one clogged 25%.
chrisjm91
- Year and Model: 95 Volvo 850T5
Just took her for a spin and its running great. I replaced the oil cap seal and dipstick tube gasket. After the cruise, I popped the hood and behold OIL spewed everywhere again
ive replaced the oil trap, cleaned the ports and heard bubbling when I blew into the ports. I replaced all the vacuum lines and cleaned the PTC nipple. Ive cleaned everything and its still blowing oil and smoke from the tube, any idea's? ? ?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
From where?
Dipstick?
How oil escapes through new o-rings from dipstick?
If o- rings are appropriate...the bad engine would make so much pressure that it would force out dipstick out from it's tube.Oil could not pass through new dipstick seals without forcing out a dipstick.
I wonder if any of pcv system hoses are pinched somewhere during installation and could that be a reason for oil forcing through dipstick.
It's either that or the piston rings or headgasket.Bad headgasket doesn't always mean oil in coolant or vice versa.
How did you replaced dipstick o-rings if you actually don't have a dipstick handle at all?Those rings fits onto a handle.
Dipstick?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
