bmdubya1198,
It seems more appropriate for me to respond to your "VOL-FCR can read some ECUs' DTCs, but can not read '98 V70 GLT transmission ECU's DTCs" problem in the new thread that you created on 2015-09-25: https://www.matthewsvolvosite.com/forums ... =1&t=72124
So that's where I'm headed -- after reviewing the "build" thread that's linked to in your signature: https://www.matthewsvolvosite.com/forums ... =1&t=71579
Thanks for focusing on your particular problem in a new thread.
esl_97_850_T5
VOL-FCR software and connector cables advice needed
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
- Has thanked: 316 times
- Been thanked: 531 times
Yes, I realized that my problem really wasn't at fault of the program, and I should go to another thread. I won't keep renewing this one!esl_97_850_T5 wrote:bmdubya1198,
esl_97_850_T5
- Year and Model: Many Volvos
- Been thanked: 76 times
Are you running the crack file? What you typically get is a demo program (the buttons don't work) and a separate crack file. You launch the program from the crack file in order for the buttons to function.bmdubya1198 wrote:I got my VAG-COM KKL cable today, and I was able to successfully read come codes (SRS and climate control, two things I know are bad) but I can't get the transmission to give me any codes. VOL-FCR tells me that connection was lost, but if I go to another item, such as SRS, it works fine. It seems I can't reset the service light, either. How can I get transmission codes?
If you have a "readme" file it will explain where the files should be located and launched from.
esl_97_850_T5
Lee,
I assumed he had gotten past that part, since in this post https://www.matthewsvolvosite.com/forums ... 56#p379837 in his "build" thread, he had displayed the pictures of Vol-FCR SRS and ECC DTCs, then in a response to erikv11's following post in that thread, bmdubya1198 said he had cleared most of the SRS DTCs and all of the ECC DTCs.
Would it be possible for him to use Vol-FCR to clear some of the SRS DTCs and all of the ECC DTCs if he hadn't performed the "launch the program from the crack file in order for the buttons to function" procedure that you mentioned?
In any case, it'll be good for bmdubya1198 to answer your question, since if he hadn't performed that "launch the program from the crack file" procedure, I'm obviously barking up the wrong tree in my responses.
esl_97_850_T5
esl_97_850_T5
Yes, I had to install the demo, then open the crack file, which is what I used.Ozark Lee wrote:Are you running the crack file? What you typically get is a demo program (the buttons don't work) and a separate crack file. You launch the program from the crack file in order for the buttons to function.bmdubya1198 wrote:I got my VAG-COM KKL cable today, and I was able to successfully read come codes (SRS and climate control, two things I know are bad) but I can't get the transmission to give me any codes. VOL-FCR tells me that connection was lost, but if I go to another item, such as SRS, it works fine. It seems I can't reset the service light, either. How can I get transmission codes?
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
I don't own a windows computer (except a Surface 3) but I do run XP and Windows 7 on my Mac laptop as virtual machines using Fusion. Does anyone know if vol-fcr can run on either of these virtual machine configurations? I assume my Surface 3 cannot run vol-fcr because Surface 3 shipped with Windows 8 and can run Windows 10 but I don't think it can run XP or Windows 7 (unless as a virtual machine ... again).
Dave
Dave
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
You shouldn't have any problem running VOL-FCR on your Surface 3, whether it's running Windows 8/8.1 or 10. You just have to set the VAG COM cable to COM1 in order for the program to detect it. I am running VOL-FCR on my HP laptop running Windows 10 with no problem.enotslim wrote:I don't own a windows computer (except a Surface 3) but I do run XP and Windows 7 on my Mac laptop as virtual machines using Fusion. Does anyone know if vol-fcr can run on either of these virtual machine configurations? I assume my Surface 3 cannot run vol-fcr because Surface 3 shipped with Windows 8 and can run Windows 10 but I don't think it can run XP or Windows 7 (unless as a virtual machine ... again).
Dave
You could probably run it on your Mac just fine, as well. As long as you can set a USB port to COM1 port on the virtual machine.
enotslim
Thanks. I assumed VOL-FCR required XP or Windows 7. Waiting for the cable to arrive. I'll try it out on both my Surface and Mac laptop.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Nice, good to know!cptkosmos wrote:I bought the cheapest USB cable i can find from ebay and it had CH340 chip. It worked just fine out of the box with Vol-FCR and Win7 in Virtualbox in Linux.
- 11 Replies
- 6856 Views
Last post by ZuluR
- 767 Views
Last post by Noerty
- 2542 Views
Last post by bmdubya1198
- 1025 Views
- 4571 Views
Last post by galexie64
