If you have 10.5 at the relay, what is battery voltage?
If there's a significant difference, you may have bad
contacts in overload relay 2/31, ( position 106 ).
Overload relays 105 & 106 don't monitor voltage, as
previously stated in this post. They just provide an auxiliary
set of contacts for accessories that go on and off with the
ignition switch to prevent an overloading of the actual ignition
switch contacts. If the contacts are failing, there could be
extra current draw that reduces voltage and blows fuses.
94 850 Turbo keeps blowing fuel pump relays
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If you're talking about the fuel pump relay, #2/23,draser wrote:Several things going on here: there's this overload relay that monitors current for the pump, so when car quits you can check volts on blue/red wire that powers relay contact. Then, there's the relay coil voltage on yel/gray wire coming from ecu which can be checked when engine quits. Fuse for pump is 15 amps. There are also 2 grounds, one for relay coil in electrical box and one for pp under the rear seat. The coil gnd can be ohmed to chassis, use meter lower ohm scale, wire at relay socket is black, and pump gnd is black also. You should read zero ohms for gnd wires.
please call it the fuel pump relay to avoid confusion.
Other research mentioned the cam position sensor and crank shaft position sensor. I swapped these out from my parts car and still no start. As a test we did a spark test, now getting no spark. The ignition system is pretty new. Is there a sensor that may have went bad causing no spark?
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
Read 13.6 on the battery, still a no start. Question, the currently install Cam Position sensor came out of a 98 S 70 Turbo, is it compatible with my 94 850 Turbo?
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
Honestly didn't have a chance to check, had to strip out the last of the parts off the 98. It's going to the bone yard today. I'll check and get back to you.
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
- 15 Replies
- 3115 Views
- 2020 Views
Last post by 90 Beater
- 1384 Views
Last post by Richard99
- 11 Replies
- 3888 Views
Last post by dwhite66
- 1387 Views
Last post by SuperHerman
