Just got a 2000 V70XCSE
The children....thanks for thinking of them....
- Has thanked: 316 times
- Been thanked: 531 times
Hell, they sell their nasty brown antifreeze, I could buy oil from them!abscate wrote:Did you check the oil in the junk yard car ? If it looks clean you can drain and use for your next oil change. Charge the junkyard back for waste disposalbmdubya1198 wrote:I'll let you know if I decide to get one, Neil!
Still looking for the console piece. One car at the pull a part had a decent one, but the screw mounts were mostly broken. I don't want one that's all scratched up, peeled, or straight up doesn't match. I don't want to have to go to eBay and pay $50 for it either.
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
A/C wasn't working right so evacuated system and recharged, the clutch kicked in so I'll just add another can and should be good to go.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
As far as know this guy was running regular oil/synthetic blend oil but he did change oil/filter during proper intervals. He had a K&N air filter but pulled that out and put in a Mann or Mayle filter. I put the new purge valve in place, cleaned anything that looked dirty but that wasn't really a big job because she's been well kept. I put in a bottle of Octane Booster and filled her up with 93 at the pump. It surprises me that most Turbo Volvo owners don't realize there suppose to use 91 octane or better. I'm going to order some fresh ATF and 6 qts. of LM w/Mann oil filter from FCP. I also have to drain the coolant system since this guy used green coolant instead of the blue NF coolant.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
You only need the higher octane for better performance, turbo engines actually have low compression. I know the T5 is 8.5:1, I use the high octane for better performance though, if it helps longevity great but I don't think it is required except when the vehicle is loaded or in hot climate.shiloh51933 wrote:As far as know this guy was running regular oil/synthetic blend oil but he did change oil/filter during proper intervals. He had a K&N air filter but pulled that out and put in a Mann or Mayle filter. I put the new purge valve in place, cleaned anything that looked dirty but that wasn't really a big job because she's been well kept. I put in a bottle of Octane Booster and filled her up with 93 at the pump. It surprises me that most Turbo Volvo owners don't realize there suppose to use 91 octane or better. I'm going to order some fresh ATF and 6 qts. of LM w/Mann oil filter from FCP. I also have to drain the coolant system since this guy used green coolant instead of the blue NF coolant.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Add the usual verbiage that the 91 octane recommendation in the manual is actually our 87 octane here in the States - no idea about Canada though.
I drive like an old fart so I put 91 in the P2 NA (high compression) and 87 in the P80 turbo, unless Im towing in which case it also gets 91.
corrected 97 octane to 87 octane
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
The other way around, yes?abscate wrote:Add the usual verbiage that the 91 octane recommendation in the manual is actually our 97 octane here in the States.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
as corrected. I was working on my e-brake again...Sommerfeldt wrote:The other way around, yes?abscate wrote:Add the usual verbiage that the 91 octane recommendation in the manual is actually our 97 octane here in the States.
- S
EU 91 Octane is US 87 octane.
I like to play safe and I don't know who to listen to. Someone mentions coolant, you get a few that say regular green is fine, you get others saying PentoFrost NF, then some saying Zerex G-05, then the ones who say Genuine Volvo only. I've learned with fluids to take everyone's recommendations and form my own opinions based on that.
93 octane only for my car. I drive harder and I'm looking for higher performance, so it's not like I'm wasting money using it.
- 900 Views
Last post by shiloh51933
- 860 Views
Last post by misha
- 1916 Views
Last post by aethera
- 1652 Views
Last post by NJS1982
- 1868 Views
Last post by 101
