Vida 2014D Times out 12/31/2017 23:59 Topic is solved
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I just redid the 2014D patch to include the required changes for the Chinese knock offs - may work for canned VMs as well. Runs exactly like the one they had. Copy to root of C: and double click. Basically I just modified the license file so it will import an expiration of 2037.
copy below code into a file and rename the file extension to DOT torrent. (Example of 2014D.torrent)
Double click it afterwards.
Works with Vuze's bit-torrent client.
Code: Select all
d8:announce59:dht://49BA6C6DEEABC4AB112993C13A2BB5499AC69A43.dht/announce18:azureus_propertiesd17:dht_backup_enablei1ee7:comment37:Volvo DICE 2014D Patch - expires 203713:comment.utf-837:Volvo DICE 2014D Patch - expires 203710:created by15:Azureus/5.7.6.013:creation datei1515690529e8:encoding5:UTF-84:infod4:ed2k16:©Õâz`fS<OcÛKo6:lengthi140788e4:name19:2014Dv2_EXP2037.exe10:name.utf-819:2014Dv2_EXP2037.exe12:piece lengthi32768e6:pieces100:‹mÆÎš¤£fñ¹»†ÙÃÓV8•Kàùsʆs»2¤DÑŸ }ÿ«kñJ­”}A/Ù5ԁÊÕr!xÿ"+šÓ)ÐÊ|û=ñuþUiHx7øç¦*1*º›—çÅæ„Ó¤7:privatei0e4:sha120:ÛxŸÅq«î_ïtÿŠ€Wã¿„žee
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Unable to load, not valid bencoding
Active
Past
bojified
Year and Model: 2003 XC70, 2004 S80
Has thanked: 1 time
Been thanked: 2 times
Post by bojified »
First off THANK YOU to all the contributors on this helpful website.
I had two laptops loaded with two different versions both up and running fine last I used them in November. One is version 2014 on a window 10 computer and the other 2012 on a windows 7. I had been using both on my two P2's at different times this fall and both worked great.
Now they both attempt to start up and I receive a red warning "No Valid Subscription" which I assume it what the patches in this thread is to fix. However I have repeatedly downloaded and installed both patched on the appropriate laptop and I still receive the same warning.
Am I looking at this correctly and these patches are a fix for the No Valid Subscription issue?
I have installed them on the host on the root of the host drive- is this correct?
Many thanks for the continued stellar help!
Scot
2004 S80 Wife's daily driver. Still have, 2003 XC70 T Daily Driver. Still have, 1997 854 Kept going for daughter, 1992 944 - Diplomat Delivery, 1997 855, 1989 744 saved my life!, 1987 744 T, 1988 780 BERTONE, 1988 765 T, 1987 744 T, 1981 244 DSL, 1974 164, 1976 265 PVR, 1981 264 GLE, 1971 145 DL, 1976 245 DL
RickHaleParker
Correct
If you are running Vida in a VM this is incorrect. You get the patches into the VM and install them in the root drive of the VM, not the host. The patch must be done in the operating system that is running Vida not the Operating System that is hosting the VM.
Active
Past
bojified
Has thanked: 1 time
Post by bojified »
RickHaleParker wrote: 11 Jan 2018, 19:12 Am I looking at this correctly and these patches are a fix for the No Valid Subscription issue?
Correct
Excellent and thank you. Totally missed where to install. Works perfectly.
wizechatmgr
RickHaleParker wrote: 11 Jan 2018, 16:50 copy below code into a file and rename the file extension to DOT torrent. (Example of 2014D.torrent)
That moment when something works fine on your machine, but you realize it doesn't work on others... Grrr.
PM me, I'll toss it somewhere you can download directly in the next couple of days.
merlin1
Year and Model: 2009 v50
Post by merlin1 »
Hi I have the same issue worked ok for 3 years now wont let me log in , mine came already on a laptop can anybody help please as I am not a teckie just a grease monkey thanks in advance
RickHaleParker
Merlin 1, Which version of Vida is on the laptop?
Active
Past
merlin1
Post by merlin1 »
Sorry for the delay 2014d cheers
RickHaleParker
  • (1) Go to the first page of this topic.
    (2) Download the file 2014A-B-D-2099.zip.
    (3) The instruction are in the same message.
Active
Past
