1998 S70 PnP switch 9466012, bad aftermarket new part Topic is solved
ferocity02
Year and Model: 1998 S70 GLT
Been thanked: 14 times
Post by ferocity02 »
UPDATE... A couple months after finding the pushed pin on the PNP switch, the issue came back. It was much more intermittent, happening once every few weeks. So while frustrated beyond belief, I neglected the issue. But recently it has been doing it every other day and needs my attention once again...
So I'm back to square one.
ferocity02
Oly850 wrote: 05 Mar 2018, 21:03 I had this issue in my '96 850 a few years back. I replaced the PNP switch which improved things, but what really solved it was finding the melted wire short in the harness going away from the PNP switch to the ECM. Found it by looking for shorts to ground on the harness. I'll separated wires and reinsulated them, whamo problem went totally away.
Do you recall whereabouts in the harness the short was located? I think that might be my next step. I'm also contemplating just running new wires between the PNP switch and the transmission computer to tally rule out the wiring.
ferocity02
Bump!
ferocity02
Bump!
ferocity02
UPDATE:
I found the issue. The replacement range switch was garbage. The construction inside does not provide a real positive connection. I cleaned the switch and stretched out the springs to provide more force on the tabs. The issue seems to be fixed for the time being. If it happens again my plan is to get a used OEM switch and rebuild it, or just get a new OEM switch, but they are pretty expensive.
Has thanked: 1610 times
Been thanked: 4068 times
Can you name the defective brand so we can add it to our wall of shame?
Parts that don’t work out of box don’t deserve our money nor our time.
ferocity02
It is Pro Parts, or Professional Parts. Their part number is 28430012. The Volvo part number is 9466012.
FCP Euro used to sell it, but I see they no longer do ever since I sent back the first one.
...thanks added and green box checked.
Gouws
Year and Model: Volvo S70 T5 1998
Post by Gouws »
Hi sorry my man..can you please explain to me where are those switches(pnp) (s/e/w)mode switch and the and cable to mode selector.....please and a milion thanks....
