That looks amazing. Is there a model number I can reference?RickHaleParker wrote: 12 Sep 2018, 00:20Just bought a wheeled Stanley from Walmart for $22.00. Makes a world of difference when raiding Pick-n-Pulls for parts.
A tools show off thread... ?
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Here https://www.walmart.com/ip/STANLEY-STST ... p/26524588
In Canada the same costs $120
https://www.walmart.ca/en/ip/stanley-mo ... 0137707762
- Has thanked: 316 times
- Been thanked: 531 times
That would be awesome at the junkyard!
- oragex
I went to check it out. The idea is great, I know there are other brands out there with a similar product but this one at walmart has a short handle for me (I'm 6ft tall). The upper box is huge but very thin plastic and the hinges won't hold when packed with tools, but it's not intended to be kept by hand anyway. Too bad the handle is too short for me because it's really interesting.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Someone have me a set of these, they might be called lobster claw flares, they work great.
Regular flares bought at the auto store opened up first try, tossed the whole set in the trash.
These only pull from one side and can't bend open.
I've never seen them for sale.
Made in mexico.
Made in mexico.
- prwood
I use these crowfoot flare nuts when working with power steering lines:
https://www.harborfreight.com/7-pc-38-i ... 68999.html
Cars I've owned:
- jonesg
I have those, they work good.prwood wrote: 13 Sep 2018, 08:21 I use these crowfoot flare nuts when working with power steering lines:
- RickHaleParker
- Been thanked: 980 times
I don't need this often but when I do it is a Godsend.
It is not variable speed, it is corded and it is bulky but at 1050ft-lb (1423Nm) of torque, removing rusted Axle nuts is like spreading butter.
Bauer Model #1882E-B, $120.00 at Harbor Freight.
Active
Past
Past
- RickHaleParker
Craftsman Extreme Grip Wrenches.
Anybody that turns bolts should have a set of these. You move the lever and the box end clamps down on the nut or bolt head. Unlike conventional wrenches, these wrenches lock down on the center of the flats rather then at the corners like conventional wrenches. Allowing one to turn even a badly rounded head or nut. The time and hassle one is spared the first time one needs a Craftsman Extreme Grip Wrench, will pay for the set.
The open end let one reposition the wrench without removing the wrench from the bolt head or nut. Good for tight space work.
One set works on both Metric ans SAE.
Available at Sears or wherever Craftsman tools are sold.
Active
Past
Past
- 2745 Views
Last post by matthew1
- 13040 Views
- 11 Replies
- 19527 Views
Last post by volvolugnut
- 1271 Views
Last post by RickHaleParker
- 1622 Views
Last post by JRL
