07 S60 Immobilizer / Communication Errors / No Start
d3ktrix
Year and Model: 2007 S60
Has thanked: 7 times
Post by d3ktrix »
Yeah the under engine splash pan is in place, never ran without it.
No PS fluid leaking near the computers.
I've done the best I can to check every connector/plug/ground I can find and haven't found any signs of corrosion anywhere else. Including all the connections on the CEM.
The plastic box cover for the EMC/TMC had 1 broken clip closest to the fender allowing it to flip up easy and 1" of it's rubber seal was missing. And the EMC it self is just a metal clam shell with zero seal. So I'm guessing water just splashed in past the lid seal. You can see signs of where water has run down the outside of alum plate on the ECM.
I ordered a new plastic lid for the ECM/TCM box.
d3ktrix
Post by d3ktrix »
Is it safe to remove the ECM, hook the battery back up and see if the car behaves any different?
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
The ECM is a critical car component. I don't see what you would gain and expect that every other system would try to prevent the car from starting and setting faults.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
d3ktrix wrote: 28 Apr 2019, 12:29 Is it safe to remove the ECM, hook the battery back up and see if the car behaves any different?
A lobotomy is not going to help.
ECM = Engine Control Module, it is the Engine's brain.
How functional would you be if I took your brain out?
I hope it would not be an improvement. :wink:
Active
Past
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
No, the engine would probably not fire up and maybe not even crank
But you can remove the ECM to inspect the connections for any corrosion/water contamination - be sure to undo the battery first www.youtube.com/watch?v=cQYOiS__oyo
